Thread: HSS-3200 JE Hall
18-05-2012, 07:33 AM #1
HSS-3200 JE Hall
Dear Friends,
Please I want HSS-3200 JE Hall Semi-hermetic screw compressor repair/maintenance
manual as I am removing stator for replacement. mail to kartheekus@yahoo.com
12-07-2012, 01:04 PM #2
Re: HSS-3200 JE Hall
You don't rebuild these on site they are service exchange machines.
The Bridge Keeper
'Answer me these questions three, n'er the other side ye see.'
What is your name?
What is your favourite colour?
What is your suction superheat?
12-07-2012, 06:39 PM #3
Hi you can rebuild these on site,halls supply full gasket set,shim set,the bearings are universal. The only thing they dont supply is the main rotor. And these are really easy to rebuild
12-07-2012, 06:57 PM #4
Depending on which size machine you have.on large one you take off the suction plate and undo 8. 8mm bolts in the centre off winding housing and remove the circular plate. Its about 75mm in diameter and then undo the winding housing bolts.then using 10mmm threaded bolts jack off the winding housing.
