    toocoldtoohot's Avatar
    toocoldtoohot Guest
    Carrier Extra reefer unit F4 fuse
    Hello, The F4 fuse blew. The blown one had 20 amp on it, replaced now with same. Need to make sure it's the right amp and need to know for what the fuse is. I was trying to get the info on the carrier website, but to no avail. Just can't find the "Extra" unit anywhere else as well.
    Thanks for your help in advance.
    Jul 2007
    LIbya
    58
    72
    Re: Carrier Extra reefer unit F4 fuse
    Dear toocoldtoohot.first you shouid know why the fuse wsa blown.plz write more on the case so we can help.
    toocoldtoohot Guest
    That's what I want to know. What is the F4 fuse?Hot gas fuse?Solenoid fuse?Fuel heater fuse?I don't have a manual for the Carrier "Extra" model. Does anyone have the information?
    Nov 2009
    Canada
    123
    I think F4 is the speed solinoid fuse and should be 15A i think
    Melbourne
    347
    what micro does it have the advanced or the standard ?
    F4 on the advanced is the clutch(7.5a)
    F4 on the standard is the speed relay(15a)
    Nov 2009
    Canada
    123
    I naturally assumed a std micro as an advanced would have given more indication of the fault?
