    May 2012
    Uganda
    37
    1
    suction pressure
    Can some please give me an insight on the causes of high suction pressures in an NH3 screw compressor when the system is not on load? any other literature on the operation of NH3 refrigeration system will be highly appreciated
    thanks
    ogola
    Apr 2009
    TEXAS
    49
    28
    Re: suction pressure
    Not knowing the design of the system or putting my hands on it, I have 3 suggestions.
    1. Could it be high suction temp? maybe a unit's hot gas defrost valve is leaking by or may have a unit in defrost when all the liquid solenoids are closed.
    2. Talking a Reciprocating compressor. If false loading it, load goes away, discharge gets diverted to the suction.
    3. If a screw and economized, may have a bad regulator on the economizer line.
    Just a few that I could think of.
    Good luck!
    Jan 2006
    Croatia
    68
    2,299
    31
    Hi, Ogolan
    welcome to RE forums ...
    Quote Originally Posted by Ogolan View Post
    thanks
    ogola
    Can you, please, clarify above text in bold ....
    1. compressor is not working ... stopped
    2. or compressor is working at low capacity
    3. how high is that "high" suction pressure
    4. in the same system you have some other running compressor/s
    Best regards, Josip
    Dec 2008
    Portugal
    48
    1,044
    Also check the discharge chek valve...
