Page 2 of 2 FirstFirst 12
Results 51 to 91 of 91
  1. #51
    Feb 2012
    Bolivia
    270
    14
    Re: Starved Evaporator Troubleshooting?
    Okay... let's re-think this:
    ... It is also an advantage in heat mode at very low outdoor temperature. ...
    Not if it may trap oil.
    What diameter is the outdoor coil tube?
    Well, did anybody ever dream of calling Aramis a coward? No, certainly not!
  2. #52
    Feb 2012
    Bolivia
    270
    14
    Not if the outdoor coil could trap oil.
    What diameter is the outdoor coil tube and the compressor capacity?
  3. #53
    Apr 2001
    79
    5,071
    35
    Quote Originally Posted by Uni View Post
    To clarify,
    Roughly it's a reverse cycle A/C system, so when we test the cool mode, we'll need 27C indoor/35C outdoor. In heating mode, we'll need 20C indoor/7C outdoor. No matter how you control the climate condition, it's international standard, or AS/NZS if we're Down Under. And, we can not do all tests at the same time, for sure.
    Are you testing the system under the standard conditions for the heat mode?
    It was Air off temp - air on temp over the indoor coil in heating (ambient 24C outdoor/30C indoor)
    Ahhh... I see you are not. The outdoor temp is much too high for testing the heat mode.
  4. #54
    Sep 2008
    Australia
    59
    Yep, if the max heat mode setting > 24C, say 30C, then the system still need to heat up in that condition until indoor return air reaches the set point.
  5. #55
    Sep 2008
    Australia
    59
    Just tested with the new condenser (2/3 original size), same air flow rate, same charge and everything else.
    The results are the same, I mean most if not all parameters (both low side & high side) are unchanged.
    Total outdoor coil's tube length is approx 12m (includes all bend& returns), 3/8" tube. Pressure drop (outdoor coil inlet to suction) approx 0.1MPa.
  6. #56
    Feb 2012
    Bolivia
    270
    14
    The rule to use an internally equalized TXV is pressure drop not higher than 0.014 MPa in the coil, so when heating the Bi-flow valve will sense the wrong pressure and think it has high superheat and close.
    You must change to two externally equalized TXV with check valves like Gary mentioned.
    If you want to prove this, change the equalization to the external coil (if you can) and should experience good behavior in heating the inner coil and bad in cooling it.
  7. #57
    Apr 2001
    79
    5,071
    35
    Here's what we need:
    Evap air in temp
    Evap air out temp
    Low side pressure
    Suction line temp at TXV bulb
    Cond air in temp
    Cond air out temp
    High side pressure
    Liquid line temp at TXV
    Is the TXV externally equalized?
    If so, is the equalizer line attached to the common suction line?
  8. #58
    Sep 2008
    Australia
    59
    The sensing elements are set up like this one, further down the suction line, I believe it's external balancing, external temperature sensing type of valve.
    The difference is this one can expand in both directions as I mentioned before. And this is probably the issue. It may not efficiently span the whole (big) operating range in both modes.
    Mode: heating (Evap = outdoor coil, cond = indoor coil)
    Evap air in temp: 24C
    Evap air out temp: N/A, I'd say about 8C-15C
    Low side pressure: 0.6MPa (Suction)
    Suction line temp at TXV bulb: 13C
    Cond air in temp: 30C
    Cond air out temp: 55C
    High side pressure: 3.5MPa (discharge)
    Liquid line temp at TXV: N/A, 54C at Cond outlet
  9. #59
    Apr 2001
    79
    5,071
    35
    Both the equalizer line and the TXV bulb must be on the suction line between the reversing valve and the compressor.
  10. #60
    Sep 2008
    Australia
    59
    They are, Gary.
  11. #61
    Apr 2001
    79
    5,071
    35
    Drop the outdoor fan down to low speed and take new readings.
  12. #62
    Apr 2001
    79
    5,071
    35
    I'm beginning to suspect that it isn't just the outdoor coil that is grossly oversized, but the compressor as well.
    Even with a relatively low suction pressure, the compressor is delivering more heat to the indoor coil than it can reasonably handle. If the outdoor coil were fully loaded, the high side pressure would skyrocket.
    In order to keep the high side pressure to a reasonable level, we need to drop the suction pressure even lower.
  13. #63
    Apr 2001
    79
    5,071
    35
    (deleted double post)
  14. #64
    Sep 2008
    Australia
    59
    I am desperately trying to do the opposite. I can afford higher Head pressure, but must bring low side pressure up.
    Garry, you are right about the indoor coil, it's undersized. So what if the coil could not handle that much of hot gas and there is a mixture of gas & liquid exits the coil (we have very low subcool, another sign), then feeds to the TXV? Is that what reduce the TXV capacity and cause low suction pressure down stream?
  15. #65
    Apr 2001
    79
    5,071
    35
    Quote Originally Posted by uni View Post
    i am desperately trying to do the opposite. I can afford higher head pressure, but must bring low side pressure up.
    why???????
  16. #66
    Sep 2008
    Australia
    59
    why???????
    With the current system configuration, imagine testing the unit in heating mode at 0°C/0°C indoor/outdoor, I'd have -35°C (or even worst) evaporating temperature and this is way out of the safe operating range of the compressor.
    So I must bring this up and accept the fact that in high heat load condition (24°C/30°C), I'd have high head pressure (but still under the compressor safe operating range).
    Do you have any thought on the other question, Gary?
  17. #67
    Apr 2001
    79
    5,071
    35
    What makes you think the evaporating temperature would be that low?
  18. #68
    Sep 2008
    Australia
    59
    by Testing
    Actually, at 0°C outdoor, Tc = 31°C, Te = -42.5°C, SH = 40K.
    That's why I am so desperate.
  19. #69
    Apr 2001
    79
    5,071
    35
    Yes... I think you are confused.
  20. #70
    Sep 2008
    Australia
    59
    Yes, I'm very confused.
    How it should be then?
  21. #71
    Apr 2001
    79
    5,071
    35
    Change the outdoor fan to low speed.
  22. #72
    Apr 2001
    79
    5,071
    35
    Then adjust the TXV stem back to where it was.
  23. #73
    Apr 2001
    79
    5,071
    35
    Then keep charging until the subcooling is 10-15F/5.5-8.5K.
  24. #74
    Apr 2001
    79
    5,071
    35
    by Testing
    ... with little or no subcooling.
    A TXV controls the flow of subcooled liquid into the evaporator. If there is no subcooled liquid, it has nothing to control... so it goes wide open (regardless of adjustment) and stays there.
    Why does it have little or no subcooling and low evap temp? Because there is not enough refrigerant in the system.
    Low subcooling means there is not enough refrigerant in the high side.
    High superheat means there is not enough refrigerant in the low side.
    Not enough high side refrigerant + not enough low side refrigerant = not enough refrigerant in the system.
  25. #75
    Apr 2001
    79
    5,071
    35
    When you tested the cool mode, presumably you had the TXV adjusted properly. Once a TXV is adjusted properly, it will never need to be adjusted again... ever.
    But when you switched over to heat mode, you opened up the TXV adjustment. Big mistake. Any problems with the heat mode are not going to be solved by TXV adjustment.
    You need to get the TXV adjusted properly. And then you need to leave it alone... forever.
  26. #76
    Apr 2001
    79
    5,071
    35
    You said it worked "great" in the cool mode. That is a highly subjective statement and it doesn't tell me anything. The following tells me everything I need to know:
    Evap air in temp
    Evap air out temp
    Saturated suction temp (evap temp)
    Cond air in temp
    Cond air out temp
    Saturated condensing temp (cond temp)
    Liquid line temp near the condenser outlet
  27. #77
    Sep 2008
    Australia
    59
    Evap air in temp 27
    Evap air out temp 14
    Saturated suction temp (evap temp) -3.5
    Suction line temp at TXV bulb 10.5
    Cond air in temp 35
    Cond air out temp 55
    Saturated condensing temp (cond temp) 44
    Liquid line temp near the condenser outlet 50 (pick up hot air temp? Liquid line running along the cond air off stream, approx 400mm length)
    The reason I adjusted the TXV in heating mode is to work out the configuration that works in heating. I used a check valve & 2 captubes before for cooling & heating modes on a similar system. If after all adjustment the conclusion is the TXV is not suitable for heating mode (although it's good for cooling), then I have to get back to captube. Again, hopefully you're correct & I won't have to play with those little tubes.
    We know that bubble or flash gas in the liquid line cause the malfunction of TXV, what happens there, Gary?
    And you reckon the two cases are different?
    p/s:
    Thanks again for your knowledge & patience. I'm confused and will not give up asking until my mind is cleared up.
  28. #78
    Apr 2001
    79
    5,071
    35
    Evap air in temp 30
    Evap air out temp
    Saturated suction temp (evap temp) 4
    Suction line temp at TXV bulb 16
    Cond air in temp 50
    Cond air out temp
    Saturated condensing temp (cond temp) 56.5
    There are some important numbers missing here, but I can tell you that it was NOT working properly in cool mode, either.
    Maybe we should go back to cool mode and get it working right... and then deal with the heat mode.
  29. #79
    Sep 2008
    Australia
    59
    I have just updated the information.
    Today I fitted two sight glasses, one before & one after TXV, so we can see what happens during both modes.
  30. #80
    Apr 2001
    79
    5,071
    35
    Evap air in temp 27
    Cond air in temp 35
    Since the refrigerant in the condenser is heating the air as it flows through, it is not possible for the cond air out temp to be higher than the saturated condensing temp (SCT).
    It is also not possible for the liquid line temp to be higher than the SCT.
    The SCT is wrong.
  31. #81
    Apr 2001
    79
    5,071
    35
    First air flow:
    Evap air in temp 27
    27 - 14 = 13K evap delta-T. Ideally, the dT should be as close as possible to 11K. High dT indicates insufficient air flow. If it is not possible to increase the air flow, 13K is within acceptable limits.
    Cond air in temp 35
    55 - 35 = 20K cond dT. The cond dT should be no more than 16K. High cond dT indicates insufficient airflow. Is the condenser fan on high speed?
  32. #82
    Apr 2001
    79
    5,071
    35
    Then subcooling:
    Since SCT must be higher than air off temp, we can guesstimate that it is a few degrees higher, say 58C. The subcooling then must be at least 58 - 50 = 8K. Normal SC is 5.5-8.5K. Although the SC may be higher, indicating other problems, we know that it is at least high enough to assure liquid supply to the TXV inlet, which makes it possible to adjust superheat.
    Then the superheat:
    10.5 - -3.5 = 14K SH. Normal SH for the air conditioning range is 6.5-8.5K, so the TXV needs to be opened a little.
  33. #83
    Sep 2008
    Australia
    59
    The SCT is wrong.
    The pressure gauges came with factory's calibration certs (traceable) and still within one first year in use. Anyway, I'll calibrate them all again.
    My suspect is the Cond Air off probe. All other probes are fixed & insulated but that’s the one I move arround a lot to check different temps.
    My indoor space is very confined so that's the most of indoor airflow I could do.
    Yes, it was Indoor fan high, outdoor fan high.
    The TXV can be adjusted within +/- 02 turns. This result & previous heating results are with -2 turns (max open).
    One day I tried one size bigger and got very high head pressure & even lower suction pressure (balancing forces not right?). I gave up on that one.
    Smaller TXV gave lower head pressure & lower suction pressure at the same adjustment, charge amount & test condition.
  34. #84
    Apr 2001
    79
    5,071
    35
    If the SCT is right and the air off is wrong, that would mean the cond dT is much lower, indicating plenty of air flow. It would also mean the liquid line temp must be wrong and we may not have enough subcooled liquid to adjust the superheat. Was the sight glass clear?
    Obviously, we need accurate readings for accurate analysis.
  35. #85
    Jul 2010
    NTH.QLD Australia
    1,730
    32
    Uni,going back to post #1, and post #62 as a reference.
    Is the compressor sized/ matched to the indoor coil, or the outdoor coil? (Or neither)
    Reason for asking: As you add more gas, your high pressure increases, in heat mode.
    Temp drop across the evaporator (In cool mode) was 13K. That could be achieved with the suction pressure at 400 Kpa (58 psi), or 280 Kpa (42 psi) if the compressor is oversized.
    Discharge temperature leaving the compressor will be be significantly higher.
    I will now return to my cave incase the Jedi should choose to use mind control Adios!
  36. #86
    Sep 2008
    Australia
    59
    Hi guys, for a charge determination test using subcool (TXV system), is ambient temperature important?
    I am gonna confirm the charge amount as per Gary's suggestion.
    It's a tough question for me. I mean if talking about norminal capacity, in cooling, it's the right size (or slightly oversized) for the indoor HX, and of cource the outdoor should be as big as you can for efficiency, and the outdsoor HX in this case, is providing sufficient heat exchange capacity.
  37. #87
    Aug 2009
    New Zealand
    2,554
    has the indoor coil got very small distributor legs.
  38. #88
    Apr 2001
    79
    5,071
    35
    Yes... the liquid line is cooled by it's surroundings. It's temperature cannot be lower than the surrounding air. If the liquid line is in a hot area, such as the discharge air flow, you will not get an accurate reading.
    I generally move the sensor downstream to an area that is subject to ambient air. Then I charge to 5.5-8.5K subcooling or clear sight glass... whichever comes first.
  39. #89
    Apr 2001
    79
    5,071
    35
    Did you get the instrument calibration problem sorted out?
  40. #90
    Apr 2001
    79
    5,071
    35
    Hold the probe in the air on flow stream. If it shows the same temp as the air on probe, then it is probably not the problem.
    Tape an accurate temp probe to the side of a refrigerant jug. Attach your gauge to the jug. The saturation temp should agree with the jug surface temp.
  41. #91
    Sep 2008
    Australia
    59
    All inlet & outlet of both coil are 3/8" direct tubes. I had to make careful configuration to have acceptable distribution.
    Unfortunately it would take a week at least. I send them out to licensed body.
    The probe accuracy might not be a problem, the concern is that I physically moved it around too much so when I reviewed the data, I am not sure where it was at that point. My bad.
    I put it back in place this time.
    I meant to ask it's a common practice to use that method for charging. Something like charge it up until the bubble just finishes, or a certain SC. However, what can be seen in the sight glass in a hot 35°C day is what we see at 25°C ambient? is the method valid in most conditions?
