Results 1 to 10 of 10
    May 2012
    4
    How to remove front panel of Fujitsu ASYA12LKC (ASY35UILKC) ??
    Hello, i bought a Fujitsu ASYA12LKC (ASY35UILKC)
    i want to remove the front cover, and i do the following:
    1 i remove the "grill"
    2 remove the 2 filters
    3 2 screws at the end of both sides of the unit
    4 1 screw from the wires cover
    5 1 screw close to the wires
    What do i have to do now?
    Oct 2007
    manchester
    5,639
    45
    Re: How to remove front panel of Fujitsu ASYA12LKC (ASY35UILKC) ??
    yank the bottom forward to cover the air outlet,
    take the facia off that covers the filters, stick fingertips between the top of the coil to prise the top away- theres 3 lugs where it clamps to the back plate, then pull forwards- be careful not to yank it off the wall bracket/drag the fixings off the wall-its tricky- good luck
    Apr 2011
    35
    41
    I hate them! Other manufacturers make it so much easier feel like I'm going to break it each time!
    May 2012
    4
    Question Re: How to remove front panel of Fujitsu ASYA12LKC (ASY35UILKC) ??
    Thank you install.
    Still not able to remove it.
    Any other explanation would be great.
    Oct 2007
    manchester
    5,639
    45
    you know the casing is in 2 pieces- there is a seam running parallel with the outlet that splits-just behind the screws with the plastic covers- this should pull forward about an inch then attack it from the top
    May 2012
    4
    i see the seam, i know it should pull forward about an inch, thats the problem, it doesn't, i'll try later.
    thanx again
    3,856
    Oct 2007
    manchester
    5,639
    45
    i love some of th cautions when installing-(1) The power source capacity must be the sum of the air conditioner current and the current of other electrical appliances. When the
    current contracted capacity is insufficient, change the contracted capacity.
    (2) When the voltage is low and the air conditioner is difficult to start, contact the power company for increasing the voltage.
    Oct 2007
    manchester
    5,639
    45
    http://youtu.be/gxVXu8Ers8Q
    2 min 20 sec and the dude removes the facia- similar to fujitsu
    http://youtu.be/uE8FO9vjMyQ
    again different style but shows how to unclip
    sources from you tube
    May 2012
    4
    Thank you install
