Results 1 to 8 of 8
    Aug 2009
    Manchester
    178
    15
    Isotech IMP3000N multi meter
    Hi all the company has replaced my old battered multimeter with a new Isotec 3000N. The only problem is it isn't reading anything not voltage resistance nothing just stays at zero. I have asked the bosses if it needs activating via some method of calibration. They keep saying it is brand new and so it doesn't need calibrating for a year or so. I have followed the instructions for settings and connecting the leads. Before I hand it back has anyone else had one of these and does it need a calibration from new in order to use it. or could mine be faulty. Other equipment we have had over the years was good to go from new already calibrated.Thanks
    Sep 2003
    ISRAEL
    72
    4,248
    Re: Isotech IMP3000N multi meter
    Did you put the battery in?
    Jun 2009
    Lusk , Dublin
    1,115
    Does it have fused test leads??
    Stu
    Tool's ? check ! Condom's ? check !
    Oct 2007
    manchester
    5,639
    45
    in that case you have no volts and no resistance-get an apprentice to touch it first to make sure its dead! haha
    11,025
    Check the battery and check the internal fuses but first check the battery.
    Aug 2009
    Manchester
    178
    15
    Yes it has battery in brand new there is power just not reading anything and no leads are not fused I read instructions again
    Jun 2009
    Lusk , Dublin
    1,115
    Another obvious one is the hold buttoon depressed..
    Oct 2007
    manchester
    5,639
    45
    also ****e leads- does it register current?-thats the amps setting! haha
    - if its new then get it sent back!
    Quote Originally Posted by stufus View Post
