Results 1 to 14 of 14
    4,713
    Using Oxygen and Acetylene Cylinders
    Hi Guys.
    Back in the dim and distant past when just a sprog, I was taught that when preparing to use Oxy/Acetylene cylinders.
    You open both using the bottle key, so that either can be shut off in 1 quick movement. You should not have to reinsert the bottle key to close off the valve.
    Also that it was necessary to leave the bottle key in the Acetylene Cylinder. Because this was the catalyst and Oxygen will not burn on it's own.
    With this in mind I asked our apprentice to set up the porta-pack prior to doing some brazing. Asking how he had been taught to set them up?
    "Open both valves 1/2 a turn and leave the key in the Oxygen!"
    Apparently He and his contemporaries have been told you leave the key in the Oxygen as that is the cylinder that would explode! (Due to the Higher pressures I assume?)
    What does anyone think?
    manchester
    5,639
    Re: Using Oxygen and Acetylene Cylinders
    buy 2 bottle keys- problem solved
    11,025
    I suppose that you could say the the oxygen will help to 'feed' a fire but as you say the acetylene is a fuel source.
    Jul 2010
    NTH.QLD Australia
    1,730
    32
    Bottles here don't have keys. Hand valves now and flash-back arrestors on your lines. Shut off Acetylene first.
    3,853
    Think i'd leave the key in the acetylene bottle, though since switching to A-gas, they have hand valves so no key needed!
    Am looking at an alternative to acetylene that is safer but still has a similar heat output, will post details if its a goer!
    manchester
    5,639
    petrogen system is the way forward -get 1 bought monkeyspanners , cant wait to see the videos you could do with 1 of them
    http://youtu.be/SabpLuqd2ZA
    3,853
    Their uk agent is at a trade show next month so am planning to go and see how much damage i could do with one!
    Feb 2009
    telford
    2,090
    33
    they key in the oxygen and cracked open half a turn thats what i was taught
    Jan 2008
    77
    Hi Guys,
    This image is taken from the BRA Brazing code of practice and relates to leaving the key in the acetylene as this is the fuel gas and source of combustion.
    Hope that helps.
    Aug 2007
    Adelaide Australia
    70
    562
    I was taught the same as you Griz, leave the key in the Acetylene bottle but as mikeref said all the bottles here have hand valves so no longer require a bottle key.
    Paul
    Apr 2007
    371
    Did a renewal on a Pipework and Brazing course a couple of years ago and they said Oxygen.....makes no real difference now that my acetylene bottle has a hand valve.....
    3,362
    Side issue, but are the dangers or grease,oil/oxygen being mixed bought up these days with the big push on safety
    & awareness?
    Apr 2012
    United Kingdom
    56
    1
    & awareness?
    Just finished a Brazing course - yes they often mentioned the explosive mix of grease and oxygen.
    No mention of which key to be left in but we used propane as they couldn't get insurance for acetylene. Hand valves on propane and key left in oxygen.
    Jun 2009
    Lusk , Dublin
    1,115
    I'm sure it is still mentioned as a matter of course ,however some twat over here decided to pressure test a condenser with oxygen a couple of years back in a multi story carpark. the resulting blast almost killed three of them as the low ceiling left no room to disapate the blast .
    Suppose you live and learn (if you get a second chance)
    Stu
    & awareness?
