    Feb 2008
    Portugal
    207
    Wireless sensor switch for air con units
    Hi does any body no where I can buy a wireless switch or make to switch indoor air con units off when no one is in the room we have tried a couple of makes but had no luck
    5,668
    Re: Wireless sensor switch for air con units
    Why not use a PIR sensor with built in timer overrun?
    http://www.conrad-uk.com/ce/en/overv...ionPIR-sensors
    Feb 2008
    Portugal
    207
    Thanks Frank we have a look tried a few does not work I look at site
    manchester
    5,639
    daikin wall mounts have an i see sensor-that alters the setpoint by 2 deg for economy mode after 30 mins
    Feb 2008
    Portugal
    207
    Daikin and panasonic have these new energy sensors need to use for older units
    manchester
    5,639
    any pir sensor rated for over 3 amp
    but if the system has a condensate pump make sure the pump is wired before the pir to enable running if needed
    Feb 2008
    Portugal
    207
    There no pumps on these where would get a pir and how do I set this up to the air con indoor unit as we want it to cut off after 15mins when no One in room
    Jan 2009
    Canary Islands
    144
    www.ecosense.uk.com
    Try this company. Haven't installed any yet, but looks perfect.
    Regards, Graham
    en boca cerrada no entran moscas
