Thread: Ahu
    Apr 2012
    Philippines
    36
    7
    Ahu
    Can anyone suggest suppliers for the following:
    1. Volume damper
    2. Motorized damper w/o actuator
    3. Back draft damper
    4. Fire Damper
    5. Pressure relief damper
    6. Supply/return/exhaust air register
    Feb 2007
    2,473
    45
    Don't know about in your neck of the woods but here in UK / Europe, Lindab is pretty good.
    You never know, they might deliver...
    Jun 2010
    Ireland
    168
    15
    Re: Ahu
    Halton would be good for any of those (again not sure of what's available in you back garden, tho they have offices in China, Japan and Malaysia)
    Apr 2012
    Philippines
    36
    7
    Re: Ahu
    RSTC thank you for the response. there's no halton in our area.
    Oct 2001
    Nottingham UK
    5,668
    Re: Ahu
    Try Systemair.....they have branches worldwide
    http://www.systemair.com/corp-en/sys..._catalogue_int
    And....no I don't work for them
    Mar 2008
    philippines
    61
    95
    Re: Ahu
    yabby,
    are you setting up a centralized a/c system or a cold air distribution for cold storage facilities ? there is an existing group or organization of cold storage operators, will check their name. sorry, i am not a member of said group. if what you are setting up is an ice plant, i can refer you to some contacts, locally. unless you want to source elsewhere
