Thread: Ahu
26-04-2012, 07:15 AM #1
Ahu
Can anyone suggest suppliers for the following:
1. Volume damper
2. Motorized damper w/o actuator
3. Back draft damper
4. Fire Damper
5. Pressure relief damper
6. Supply/return/exhaust air register
26-04-2012, 07:34 AM #2
Don't know about in your neck of the woods but here in UK / Europe, Lindab is pretty good.
You never know, they might deliver...
26-04-2012, 09:10 AM #3
Re: Ahu
Halton would be good for any of those (again not sure of what's available in you back garden, tho they have offices in China, Japan and Malaysia)
26-04-2012, 10:12 AM #4
Re: Ahu
RSTC thank you for the response. there's no halton in our area.
26-04-2012, 07:02 PM #5
Re: Ahu
Try Systemair.....they have branches worldwide
http://www.systemair.com/corp-en/sys..._catalogue_int
And....no I don't work for them
30-04-2012, 02:05 PM #6
Re: Ahu
yabby,
are you setting up a centralized a/c system or a cold air distribution for cold storage facilities ? there is an existing group or organization of cold storage operators, will check their name. sorry, i am not a member of said group. if what you are setting up is an ice plant, i can refer you to some contacts, locally. unless you want to source elsewhere
