16-04-2012, 09:09 AM #1
Copper pipe and brass compression fittings for 30GX carrier chillers
I am looking for the brass compression fitting/adaptor with flat face for oil level switch at receiver for a 30GX carrier chiller.
I am located in Dubai. Was not able to find this fitting.
Please advise where i can get it.
16-04-2012, 09:38 AM #2
Re: Copper pipe and brass compression fittings for 30GX carrier chillers
BrassCOMPFitt.jpg see the attached photograph of fitting.
17-04-2012, 07:34 PM #3
What happened leaks ??? I had similar problem with Trane rooftop they send me new one ... how old is that chiller ??? Btw dont forget on R22 policy lol .
17-04-2012, 07:45 PM #4
18-04-2012, 09:23 AM #5
Hi, thanks for response. this chiller is 10 years old.
05-08-2012, 08:12 PM #6
Have you tried to shop for it online? If you can't find that kind of copper pipe and brass compression fitting at your place, for sure you'll find it online. With that, you can also select the characteristic of the one you need over the wide range of choices.
________________________________________
plumbing
