    Apr 2012
    7
    TK SB-200 How to clear code 3
    Hi.
    Had alarm codes 11 and 3 on SB-200. Was able to clear code 11. But cant seem to clear code 3. How can I clear that code? Thank You!
    Melbourne
    347
    Re: TK SB-200 How to clear code 3
    power on, cycles off, hold TK and clear buttons, press Alarm press clear, if it doesn't clear scroll to DDUR press TK and clear, press alarm and clear buttons.
    Doesn't fix the problem
    Apr 2012
    7
    Replaced the sensor, cleared the code, all good now, Thanks!
    Nov 2010
    The Netherlands
    64
    134
    14
    Code 3 is return sensor defective. Code 11 is unit controlling on alternative sensor (normally discharge sensor).
    Are sure the sensor is good?
    Apr 2012
    7
    Robert Hilton, going to get it checked after I get unloaded. Just wanted to clear the code to bring my status light back to green since the unit is running ok for now.
