Thread: T800
29-04-2012, 05:31 PM #1
T800
Hello everyone, Just seen a thermoking T800 for the first time cutting out on high pressure when unit on heat a live feed to hot gas valve but no earth from micro does any one have a diagram they can send me or is there any common faults on these units i should look for?
Sandy
sandyinperth@btinternet.com
01-05-2012, 12:24 AM #2
Re: T800
I thought the T/K's switched the +ve from the micro not the ground,when its not in heat is there 12v to the solinoid then? if not you have a ground fault.
01-05-2012, 07:03 AM #3
Re: T800
not much to see on the wiring diagram, micro gives signal, LED10 lights up on relay board +ve to HGS, permanent earth.
