Results 1 to 12 of 12
    Apr 2008
    north west runcorn
    28
    1 5/8 pipe benders
    Hi there
    Right we got a job starting soon and have been told we got to bend all pipe work so what make of benders have you used that work well on 1 5/8 and 1 3/8 pipe ? Cheers for your help .
    4,707
    Re: 1 5/8 pipe benders
    Hi Cooltools
    I did not realise benders for that size are readily available?
    It's a safe bet they would be Hydraulic.
    It will be interesting to see what the guys recommend.
    Jun 2009
    Lusk , Dublin
    1,115
    Have used one of these for 1 3/8 in the past ,not easy to bend by the way, ended up doing my back.
    http://www.sitebox.ltd.uk/product/bn...ainless-steel/
    As Grizzly said for that size hydraulic would be the way to go.
    http://www.sitebox.ltd.uk/product/THHB200/irwin-hilmor-thhb200-manual-hydraulic-bending-machine-38-2/
    C
    heers
    Stu
    Jun 2010
    Ireland
    168
    Jun 2010
    Ireland
    168
    Jun 2009
    North East England
    712
    Quote Originally Posted by rstc View Post
    :d :d
    Dec 2010
    Toronto, Canada
    1,454
    Quote Originally Posted by RSTC View Post
    Yes, but it is too expensive.
    Sep 2003
    ISRAEL
    72
    4,248
    A few important points about the bender you choose, The pipe is hard copper and can "break" easily.
    The bending part must hold the pipe at 270°. The pipe must be pulled while bending.
    Dec 2010
    Toronto, Canada
    1,454
    You can anneal the hard copper if you really want to bend it but it takes time and gas.
    Jun 2010
    Ireland
    168
    ^and I'm guessing that hot work permits are an issue given that they are asking for pipe benders to be used
    3,856
    REMS do some good benders, not sure on how big they go!
    I have an old Record stand bender for 1 3/8 but its hard work!
    Feb 2010
    Ireland
    38
    82
    We always just used the A frame benders with the right size slide and form. Can be hard work alrite you really need to heat the pipe first. Have an expanders that does up to 4" now that's a real pig to control. Have seen a good hydraulic benders by REMS but it was big money at the time.
