    Apr 2012
    Iraq
    623
    air motor excilling wires
    hi every one
    i am installed a split uni ac but i found a wire that i didnt find a socket for it
    its name as i think air motor excilling wires
    so where i must connect it
    what is the utility of this wire
    Jun 2009
    Lusk , Dublin
    1,115
    Re: air motor excilling wires
    Probably a secondary fan connector for alternate static pressure if ducted.
    Stu
    Apr 2012
    Iraq
    623
    Quote Originally Posted by stufus View Post
    Stu
    can you explain more please
    Jun 2009
    Lusk , Dublin
    1,115
    If the unit is a ducted type it is common to have multiple connectors for the evap fan to allow for fan adjustments depending on the static pressure involved.
    Is the unit operating???
    Make??
    Model??
    Stu
    Apr 2012
    Iraq
    623
    thank u 4 u help
    i dont know the model of ac
    thanx
