Thread: Ranco Stat.
    May 2004
    71
    Ranco Stat.
    I'm trying to reference a Ranco fixed range stat. It's off a condesing unit connected to a spray booth.
    The part is old and worn and I can't make out any details other than the part number K50-P5623.
    I cannot find any details for this part number and Ranco have yet to get back to me to let me know if this unit has been superseded.
    Can anyone point me in the right direction ?
    Cheers.
    Jul 2009
    Illinois
    187
    15
    Re: Ranco Stat.
    What is the purpose of this stat, what are the ranges of this stat, if you know those things you should be able to easily find a suitable replacement from any number of manufacturer's
    Oct 2007
    manchester
    5,639
    45
    Re: Ranco Stat.
    http://www.uni-line.com/modules/cata...categorysearch
    these are universal and easy to fit , k50 stats refer to these
    http://www.invensyscontrolseurope.co...ct.aspx?id=148
    you need to know the operating range or the actual temp required and the differential- usually 2-4 degrees
