Results 1 to 28 of 28
Thread: Samsung RSA1DHMH
09-04-2012, 07:30 PM #1
Samsung RSA1DHMH
Hello folks
side by side fridge / freezer with water/ icemaker
i need some info on how to adjust the freezer door, the bottom right hand corner is not sealing causing frost in the freezer. the unit is level & vertical. Aquired from mother inlaw delivered by removal company. Also is it normal on this style of freezer for the temp to vary on it's own or is this due to the door problem?
thanks
09-04-2012, 07:41 PM #2
Re: Samsung RSA1DHMH
tip it back and get screwdriver on it,otherwise a hammer- tonto is ur man for a more technical answer
09-04-2012, 07:45 PM #3
guess i'll have to wait for Tonto then
09-04-2012, 08:13 PM #4
found a spares site
http://www.4mysamsung.co.uk/cgi-bin/...ung%20RSA1DHMH Hinge&brand=Samsung&model=RSA1DHMH&path=111066&part=Hinge
09-04-2012, 08:55 PM #5
was the doors removed when the fridge was moved and installed? have you checked the door seals to make sure no gaps and sealing correctly, as there is no real adjustment on these doors, just three bolts at top to hold in place.. if not cooling as it should then 1st thing put it into error code mode and see if it shows any faults
09-04-2012, 09:06 PM #6
I don’t know your model, normally household freezers have non-adjustable hinges.
What you should do is change the door gasket.
You may temporarily fix it inflating the seal injecting silicone beneath, but it won’t last.
You can check the seal pushing a thin sheet of paper. If it goes in between, the gasket is not closing the gap.
The gap in the door could affect the temperature for short periods. On long periods it could be the thermostat.
A malfunctioning thermostat can also produce frost inside.
09-04-2012, 09:11 PM #7
there no thermostats on these only senors and you cant just change door seal you have to replace whole door
09-04-2012, 09:28 PM #8
09-04-2012, 09:45 PM #9
09-04-2012, 10:05 PM #10
take door off again and refit make sure door fits tight before doing bolts up
09-04-2012, 10:05 PM #11
Is the floor level? If not it can twist the cabinet and the door won't seal as its not twisted too... Usually theres some screwy iny outy feet, might have been fine till it was filled up with food as the increased weight has an effect.
10-04-2012, 06:05 PM #12
10-04-2012, 06:07 PM #13
10-04-2012, 06:54 PM #14
check theres no play in the door when its open to ensure theres no nylon inserts missing-as monkey spanners says slackening off the bracket will give you some movement to possibly align
10-04-2012, 07:55 PM #15
10-04-2012, 08:25 PM #16
did they take the doors off and the brackets- if so did they cross the fridge door brackets with the freezer brackets ?- it would be easier to check it if you unplug it . could take the milk /bottles out- pull the fridge forward about 18inch and tilt it back so it rests against the wall and put something underneath to stop it crushing ur fingers
11-04-2012, 02:32 PM #17
11-04-2012, 08:40 PM #18
i was at work when they dropped it of so don't know other than "they took the doors off". the fridge door has a height adjuster screw at the bottom , freezer door is just bolted onto the housing
does anyone have a service manual? or point me in the right direction. no point connecting the water up for ice till i get this door sorted
11-04-2012, 09:15 PM #19
have you reported the problem to the removal men that since delivering it, theyve f****d it and put the ball in their court so to speak?-ive searched and cannot find anything
11-04-2012, 10:18 PM #20
11-04-2012, 10:19 PM #21
not if you live in norfolk!
11-04-2012, 10:25 PM #22
is it poss the door is twisted / warped , then were looking at a new door.......YIKES
11-04-2012, 10:28 PM #23
what about the white rose county?
12-04-2012, 12:45 PM #24
where bouts are you
12-04-2012, 07:12 PM #25
check yer messages
13-04-2012, 07:32 PM #26
can get someone there monday to sort
13-04-2012, 10:40 PM #27
13-04-2012, 11:37 PM #28
