Results 1 to 8 of 8
    Apr 2012
    Iraq
    36
    623
    fixing very tiny leak
    hi every one
    this is my first post
    i work in hvac department in a factory
    some time we encounter very tiny leak in window type and split type air conditioning unit
    and it take long time w/o detection
    so can any body learn how to fix it
    i heard about fixing tiny lek with chemical and by alot of method
    Sep 2003
    ISRAEL
    72
    4,248
    Re: fixing very tiny leak
    hello kefah and welcome to RE.
    Theer is no way to cut corners if you want it fixed but patient and soap, check slowly all the copper pipe work until you find the leak.
    Apr 2012
    Iraq
    36
    623
    thank you
    i ve heard about fixing it by mixing some chemical with ***** is that really
    or not
    Sep 2003
    ISRAEL
    72
    4,248
    Never heard about it, sorry.
    Feb 2007
    2,473
    45
    OK, this will open up a can of worms....
    The product you are looking for is "Super Seal" HERE
    It works a treat as long as you adhere to good engineering practices, you cut any corners or get moisture in to the system and it will turn nasty.
    We had a VRF system that lost a kilo of refrigerant every month, we knew that the leak were either in a wall or underground (cr@p installation, not by us). As a last resort we added Super Seal to the system and afterwards it was running perfectly, without leaks, for about 6 years before it was replaced (as part of a major refurb)
    On the other hand, you just have to do a quick google search and you will find all the horror stories...
    Apr 2012
    Iraq
    36
    623
    thank you pal
    Jun 2009
    Romania
    8
    Jun 2010
    Wales
    45
    Hi Kefah, & welcome to RE
    im assuming that you pressure or strength test your equipment prior to evacuating / charging it
    how long do you give for these tests, to check each window A/C is ready to carry on to the next stage?
    as like chemi-cool said using a bubble leak detection fluid is the best way apart from checking each joint whilst charged with a electronic leak detector, as i know some detectors can find leaks less than 3 grams a year?! ( very sensitive mind )
    Otherwise that superseal is that chemical it sounds like your asking about.....
