06-04-2012, 06:56 AM #1
SAMSUNG SR-L709EVSS: d ERROR ON TEMPERATURE DISPLAY.
Hi, I have a Samsung double door (twin cool) fridge. It displays d on the temperature display. I have replaced a faulty thermal fuse in the freezer section. I am able to reset the error by holding in the "Quick Freeze and Quick Cool" buttons for approximately 8 seconds. The frigde then starts-up & functions correctly. It reeches temperature setpoint, switches off and starts-up normally. The only problem is that if the mains is switched off, it does not start-up by itself and keeps flashing d on temp display. Any ideas what i can do to resolve this. Thanks!
06-04-2012, 08:06 AM #2
Re: SAMSUNG SR-L709EVSS: d ERROR ON TEMPERATURE DISPLAY.
not known d error
03-05-2012, 07:36 PM #3
Thanks for the reply Tonto. I replaced the defrost sensor in the top refrigerator compartment, and that cleared the fault.
08-10-2012, 05:49 AM #4
Hi Martinv,
I have the same problem with my fridge. Where did you purchase the defrost sensor from? what sort of price am I looking at?
08-10-2012, 11:22 AM #5
£15 we sell them for
check out my website www.airkooldomestics.co.uk
09-10-2012, 06:30 AM #6
Thankss Tonto. I managed to find the sensor. Do you know where I can get a schematic diagram for the fridge?
seen guys here years ago using some kind gas powered hydraulic lift,they just lifted unit onto small platform turned on small gas bottle(probably nitrogen ) and up they went ,never seen outdoors...
Fitting Split Outdoor units in...
