    Apr 2012
    South Africa
    59
    2
    SAMSUNG SR-L709EVSS: d ERROR ON TEMPERATURE DISPLAY.
    Hi, I have a Samsung double door (twin cool) fridge. It displays d on the temperature display. I have replaced a faulty thermal fuse in the freezer section. I am able to reset the error by holding in the "Quick Freeze and Quick Cool" buttons for approximately 8 seconds. The frigde then starts-up & functions correctly. It reeches temperature setpoint, switches off and starts-up normally. The only problem is that if the mains is switched off, it does not start-up by itself and keeps flashing d on temp display. Any ideas what i can do to resolve this. Thanks!
    Jul 2006
    norfolk
    738
    Re: SAMSUNG SR-L709EVSS: d ERROR ON TEMPERATURE DISPLAY.
    not known d error
    Apr 2012
    South Africa
    59
    2
    Thanks for the reply Tonto. I replaced the defrost sensor in the top refrigerator compartment, and that cleared the fault.
    SandroM's Avatar
    SandroM Guest
    Hi Martinv,
    I have the same problem with my fridge. Where did you purchase the defrost sensor from? what sort of price am I looking at?
    Jul 2006
    norfolk
    738
    £15 we sell them for
    check out my website www.airkooldomestics.co.uk
    SandroM's Avatar
    SandroM Guest
    Thankss Tonto. I managed to find the sensor. Do you know where I can get a schematic diagram for the fridge?
