19-03-2012, 02:31 PM #1
carrier 30gx-207 screw chiller i get one alaram 48
hi every one i have carrier 30gx-207 screw chiller i get one alaram 48 oil solenoid failure i check in manual test it's energized.& in auto. oil pump start but oil solenoid valve coil not energized, power is not comeing from scpm bord any one can helf me i need u'r support
19-03-2012, 11:34 PM #2
Re: carrier 30gx-207 screw chiller i get one alaram 48
The code 48 seems to suggest a problem with the oil valve and the fact that the oil pump is not producing pressure. With that problem the solenoid will not open.
http://eto.carrier.com/litterature/cm/13056.pdfBrian - Newton Abbot, Devon, UK
