Results 1 to 11 of 11
Thread: R22 Freezer
    Apr 2010
    Jamaica
    34
    121
    R22 Freezer
    Hello.
    I have been seeing people in forums and websites discuss R22 freezers, as if it is possible to use R22 for that, yet some people told me that I can't safely use R22 for that. My compressor is designed for R22, and I really want to be able to freeze with it, even if a change of refrigerant is required...
    This is one of the threads I saw: http://www.refrigeration-engineer.com/forums/showthread.php?22627-Blast-Freezer-with-R22
    C
    ould someone help with this?
    Thank you.
    Visit http://www.kompulsa.com/ for technology news, reviews, and more. Twitter: Kompulsa.
    Feb 2007
    2,473
    45
    Re: R22 Freezer
    Everything is possible, the question is what you are willing to pay...
    R22 @ the temperatures required for a freezer would run below 1bar on the suction side, making the compressor having to work much harder than it ever was designed for. (it will most likely also create problems with getting the oil back to the compressor)
    Anything running outside it's design envelope is likely to suffer premature failures.
    Before you decide what refrigerant your system should operate on it is good practice to check the entalphy charts for the refrigerant and properly design the system in theory, that will save a lot of hassle later.
    Apr 2010
    Jamaica
    34
    121
    Re: R22 Freezer
    I don't think this type of compressor is supposed to circulate oil, I only see air come out of it when it is on...
    (Rotary Sealed Hermetic R22 Compressor)
    Sep 2003
    ISRAEL
    72
    4,248
    Re: R22 Freezer
    As the Viking said, your compressor is not designed to work in these temps.
    A substitute for R-22 is R-422D.
    All compressors [well, almost all] circulate oil in the system.
    Apr 2010
    Jamaica
    34
    121
    Re: R22 Freezer
    Maybe you're referring to automotive air conditioning. I am talking about residential units.
    Of the four compressors I have used so far (two R134a fridge and two R22 residential air conditioner types), none of them pumped out oil.
    3,856
    Re: R22 Freezer
    Quote Originally Posted by Kompulsa View Post
    Watch this link, gives an idea of what comes out the discharge when running...
    http://www.youtube.com/watch?v=hapg3FbD9Es
    Jun 2009
    Lusk , Dublin
    1,115
    Re: R22 Freezer
    The oil is carried in the refrigerant!!!!!
    And if you are running these comps open to atmosphere , i hope you're changing the oil afterwards
    Stu
    Tool's ? check ! Condom's ? check !
    Feb 2007
    2,473
    45
    Re: R22 Freezer
    A long time ago The Viking could sometimes be seen banging his head against a brick wall but nowadays he just walks away, silently shaking his head...
    Somerset
    69
    4,698
    Re: R22 Freezer
    Wise words guys!
    Thanks for the link MS. Really interesting.
    I tried to add rep points but have got to spread the love some more first!
    Jul 2009
    Illinois
    187
    15
    Re: R22 Freezer
    Quote Originally Posted by The Viking View Post
    Amen Brother!!!!!!
    Aug 2012
    usa
    4
    Re: R22 Freezer
    in refrig school 1981 i saw a residential R22 freezer uprite 20 cu ft i believe it was a sears product
