Results 1 to 12 of 12
12-03-2012, 07:57 PM #1
Freezer cold but fridge top not working
Hi Guys
Ive looked on the forum and seen the many articles regarding frost free fridges, and yes mine is one, a jlffw2007 made for John Lewis by Electrolux. I defrosted the freezer as recommended on this forum and cleaned behind the panel. Hurray the fridge worked again, I cancelled the engineer but now after a week its stopped working again. Any ideas would be most welcome, do i need to call them back? or is it bricked?
Thanks in advance.
Steve
London
13-03-2012, 09:13 PM #2
Re: Freezer cold but fridge top not working
is the fan working, is there ice build up, have it been put into defrost mode
13-03-2012, 09:14 PM #3
has the door dropped?
14-03-2012, 07:35 AM #4
or shall we just tell him needs defrost heater
14-03-2012, 01:45 PM #5
Thanks for replying.
Where would I find the fan?
Ta
14-03-2012, 02:24 PM #6
you have cleaning cycle problem best way to help you send me model number and who made fridge .
Problem can be defrost termostat, defrosting element, defrosting timer. Same times defrosting timer is location on main electronic board this way I need yours fridge model number to on schematic were is the problem
send me email tedsa2@yahoo.ca
14-03-2012, 08:09 PM #7
Sorry mate that email was rejected. Anyway the model is 925034244-1 made by Electrolux. There is another number 8083008 don't know what it represents. I should add that when it stopped working again I got the hair dryer on the metal fins and it started to work again. I don't want to have to do that on a weekly basis though!
Thanks for your help I really appreciate it.
Steve
15-03-2012, 05:12 AM #8
Ok you have a problem with the DEFROST cycle that cleans fridge every day.
To fix this, check the freezer. But I do not even clean the ice in the freezer until after review defrostig thermostat. Therefore, the defrosting thermostat closes the contacts between 40-50 Fahrenheit above 50 farenheit but are open contact. Now check to see
defrosting heater. Best to check these two elements are the voltage checked. derosting defrosting thermostat and heater is connected in series. So voltage should be the same as the outlet. If the voltage is one of the elements is broken, if the voltage does not have to have a broken defrosting timer who is the next element or part of the integration Main board. Please reply if you have any questions I live in Canada a little far to come and fix it. find me on skype "ted.san" from Canada
Undo edits
Undo edits
15-03-2012, 08:18 AM #9
he's already been told needs to replace defrost heater if dont know what doing call a engineer to fix it
15-03-2012, 10:45 PM #10
17-03-2012, 03:56 PM #11
SIMPLE TERMS U NEED THIS http://www.4ourhouse.co.uk/cgi-bin/p...44&path=140263
26-03-2012, 09:41 PM #12
Thanks for all you help
