Results 1 to 18 of 18
    Mar 2008
    philippines
    61
    95
    oil separator advise
    good day, fellow members. can a restricted oil separator cause a high discharge in a compressor ? is there a procedure to clean the inside of the oil separator, short of opening it up ? can i use nitrogen to flush it ? the oil sep is mounted to a sabroe smc 112L nh3 compressor.
    i am just soliciting your advise, if there is a possibility that there is any other external factor contributing to the high discharge, short of opening up the compressor. restricted condenser tubes are already out of the factors. thank you
    May 2012
    59
    1,528
    Re: oil separator advise
    Quote Originally Posted by engrp View Post
    High discharge could be caused by many, many differant things.
    You need to cheack the obvious and the easy first.
    Is the condenser blocked, choked or restricted?
    Measure the temperature of the liquid coming out of the condenser and
    compare it to the condensing temperature. It should be lower.
    If the liquid line is not lower in temp than the condensing temp then
    the liquid is not condensing and it is a condenser issue.
    In answer to your question about oil seperators, yes they can restrict
    and no they are hard to check without removing and stripping down.
    If you are thinking of nitrogen flushing it why dont you fit schrader valves
    in the discharge before and after the oil sep and before and after the condenser?
    You will be able to see where any restriction is then.
    Rob
    May 2006
    India
    399
    1) usually the oil separators are hermetically sealed hence cleaning is difficult. Although you can try out by reverse flow low pressure nitrogen that can clean only dust particles that may be sticking on the baffle plate in it.first remove it from system .
    2) moreover it also depends upon the type of oil separator ;whether spiral type / baffle plate type while considering effectiveness of cleaning.
    3) yes blocking of gas path in discharge line can raise the high side pressure . Measure dis pressure on compressor outlet & outlet of oil separator ............if restriction in oil separator , outlet pr of oil separator could be lower due to restriction ............and comp high side pressure could rise.
    Dec 2008
    Portugal
    48
    1,020
    Also high superheat can contribute to the high discharge temperature.
    What are the operating condition of the compressor? Please send us the pressure measurements at inlet/outlet compressor and also the suction and discharge temperature. Register that values at 33% and 100% compressor capacity.
    About the oil separator cleaning there are specials products to dilute the debris on the mesh of the oil separators.
    3,356
    Iwould first check where the resriction might be, if there is one.
    Discharge stop on compressor & discharge non return valve after oil seperator would be next.
    Do you have a reason to believe that oil seperator could be choked up?
    Croatia
    68
    2,261
    Hi, engrp
    From Sabroe manual....
    "Sabroe oil separator consist of stainless steel wire mesh which, as a rule, needs no cleaning, nor does it get worn. Consequently, the filters cannot be removed from the oil separator."
    Maybe is there some problem with oil return back to crankshaft case and oil separator is clogged with oil, but you did not mention any problem with oil level within compressor crankcase.
    Do you have oil return controlled via solenoid valve or float control valve ... check that line but first close discharge and suction valve on compressor and evacuate compressor to atmospheric pressure ...
    To me all sounds like you have some air within your system ... try to purge your condenser/s and receiver/s. If you can to store all ammonia into evaporators and suction separator you can use a vacuum pump to evacuate condensers snd receiver...
    Best regards, Josip
    Mar 2008
    philippines
    61
    95
    thanks to all your suggestions . it seems a blocked oil sep is very remote, based from your comments. thanks again. will further check the system.
    Aug 2010
    110
    14
    Smile Re: oil separator advise
    Are you talking high discharge pressure or high discharge temperature? I would check on the obvious things first. Is the oil seperator full of oil? Have you checked the operation of the oil return system? Is the check valve operational? How are you measuring the pressure or the temperature? If I remember back the 112L is a long stroke compressor which was prone like the E series to running at high discharge temperatures. The details of the plant are a bit vague is it a single compressor plant? Is it a single stage setup or a booster plant compressor? With a few more bits of details I think we should be able to help you along the correct path.
    Aug 2010
    110
    14
    Hello Rob
    I don't think it is a good idea to use schrader valves with an ammonia compressor. Brass and NH3 are not compatible.
    3,356
    Quote Originally Posted by piewie View Post
    Hello Rob
    It may help relieve the excess pressure though!
    Croatia
    68
    2,261
    Best regards, Josip
    May 2012
    59
    1,528
    Hello Rob
    Good point.......... I missed that bit
    Rob
    May 2012
    59
    1,528
    Hello Rob
    I'm glad you noticed my diliberate mistake........
    Rob
    Croatia
    68
    2,261
    Hi, engrp
    It will be very nice, if you tell us what was wrong at the end of this case. Of course if you know.
    We were right, wrong or somewhere in the middle of the road!?!
    Thanks!
    Best regards, Josip
    Mar 2008
    philippines
    61
    95
    sorry josip, we have not dismantled the sabroe yet. we are currently overhauling the grasso rc 612, but will be opening up the sabroe a few weeks after the rc612 is on line. before i open up the sabroe, i will be doing some of the advise given in ths thread and will post it as we perform the tasks. as always, i am greatful to all of you for taking the time to give tips and comments , sorry if i have been remiss in updating you and fellow members of the results of your comments and advise.
    Croatia
    68
    2,261
    Hi, engrp
    no problem, take your time .... I was just curious ...
    Best regards, Josip
    3,356
    I have found the product "brake cleaner " extremely good for cleaning.
    Its not cheap in a 20 litre drum, but it does the job.
    You continually circulate it & it loostens up & breaks bown carbon etc.
    "brake cleaner" believe it or not is usually used for cleaning the brakes on your car.
    It will also evaporate, similar to the old R11.
    Don't catch on fire using it though!
    Mar 2008
    philippines
    61
    95
    yes, ranger1 , i have heard of this chemical. but is very expensive here. thanks for the suggestion.
