06-03-2012, 02:43 PM #1
Help! DAEWOO FRSU20DAI fridge-freezer not working, help!
My DAEWOO FRSU20DAI fridge-freezer has suddenly stopped running, from one minute to the next. Is there a reset button I can use? Or is the problem a faulty motherboard? If so can it be repaired?
(The fridge had been switched off for 3 months, when I switched it on it worked perfectly for about 30 mins, then suddenly stopped completely)
Many thanks for your help.
08-03-2012, 09:31 PM #2
Re: Help! DAEWOO FRSU20DAI fridge-freezer not working, help!
is there any power to it? can u hear compessor running?
09-03-2012, 09:38 PM #3
No there is not a sound coming from the fridge, all the lights are out too. I tested the fuses. they are all o.k.
09-03-2012, 09:43 PM #4
No there is not a sound coming from the fridge, all the lights are out too. I found two fuses, one at the bottom , one at the top, I tested them both and they are o.k., the fuse on the print is also o.k., but maybe there is another fuse somewhere?
12-03-2012, 10:46 AM #5
It could be a few things. Do you know anyone with any electrical skills?
