Results 1 to 13 of 13
    Dec 2010
    Toronto, Canada
    1,454
    3 way mix valves
    Guys, I am looking for a good supply of high Cv 3 way mixing valves, 3/4" to 1.5". Controllers need to be compact and run 0/2-10Vdc. I would prefer 24vac motors but 220-240vac will do. Does anyone know of good suppliers other than the usual suspects like Honeywell and Belimo.
    Jun 2009
    Lusk , Dublin
    1,115
    Re: 3 way mix valves
    Tool's ? check ! Condom's ? check !
    Dec 2010
    Toronto, Canada
    1,454
    Quote Originally Posted by stufus View Post
    Yea, danfoss is usually included with "the usual suspects". Any more thoughts?
    Split Croatia
    57
    6,151
    36
    I wouldn't go farther than that!
    Auckland
    74
    3,357
    37
    Berkit, I am not swearing [ spell check ] euro so probably expensive. There are wax motors but slow reaction time. I have used Shnieder motorised valves on larger applications, bleedin'expensive though. There was a cheap as chips motorised vav for chilled water we used years ago on perimetor induction units coolers, I will think about the name and get back to your. cheers magoo
    Dec 2010
    Toronto, Canada
    1,454
    Are you sure Berkit is not a swear word? I will look it up but if I mention it to someone and get punched in the face we will need to have a chat...LOL
    Dec 2010
    Ireland
    339
    15
    Quote Originally Posted by MikeHolm View Post
    Belimo make the best valves out there.
    Dec 2010
    Toronto, Canada
    1,454
    Quote Originally Posted by Bigfreeze View Post
    Yea, I know but for 1.25" the actuator gets BIG
    Dec 2010
    Ireland
    339
    15
    Not for the standard 3 way we use (LR230a). But it might be different on the mix valves although I don't see why it should.
    Sep 2003
    ISRAEL
    72
    4,248
    Mike, try here, i have used them [4"] in the past, very reliable.
    http://www.buildingtechnologies.siem...ndingPage.aspx
    Mar 2012
    usa
    3
    http://www.kele.com/control-valves.aspx
    They are very good people to deal with.
    Their kele actuator has 5 years warranty.
    Just look around their catalog
    Nov 2008
    136
    I always go for belimo if i cant get the original. beimo equipment is good well priced and good variety. helpful in Aus.
    Dec 2010
    Toronto, Canada
    1,454
    Well, I went with a Honeywell. Not too bad price and good CV.
    http://customer.honeywell.com/honeyw...aspx/VCZML6100
    http://customer.honeywell.com/honeyw...spx/VC7931ZZ11
    Thanks for the help
