Results 1 to 10 of 10
    Oct 2008
    newbury
    1,444
    37
    Copeland csemi wiring diagrams
    Chaps
    ot two new compeland semi and neither have a wireing diagram
    one is single phase and one is 3
    (both should have been 3 )
    the single phas has a terminal box labeled L1 L2 L3 so sparks threw in a 3 phase supply (as it was supposed to be 3 phase I can't blame him either)
    this is the single phase unit
    We are rewiring to single phase but I need to know why there is L1,2,3 and where the other numbered ones go to :-/
    I have scanned the web but nothing gives the full detailsDSC03915.jpgDSC03916.jpg
    3,856
    Re: Copeland csemi wiring diagrams
    Think they use the same box for single and three phase hence L1 L2 L3.... Can only suggest tracing the wiring to the relay and caps that will tell which is L,N and start.
    Feb 2009
    telford
    2,092
    33
    get in tuoch with who supplied them and demand a diagram!asap.
    Feb 2012
    Bolivia
    270
    14
    You can find the diagram here:
    http://www.emersonclimate.com/europe...8109-03)_0.pdf
    Black is Run
    Common Blue
    Start Brown
    Hope this helps.
    3,856
    Found this,
    http://www.emersonclimate.com/europe..._3154188_0.pdf
    Covers scroll model but may be helpful....
    Somerset
    69
    4,697
    Glad to be of assistance RB.
    Follow this link as the manual has referances to wiring your units on pages 11 and 25.
    http://www.mediafire.com/?n2t15mitleq
    Somerset
    69
    4,697
    Also check your email!
    Oct 2008
    newbury
    1,444
    37
    many thanks to all:-)
    Mar 2010
    Kansas USA
    75
    10
    Check ohms to establish common start run terminals on 1 ph
    3 ph would be the same between phases
    Copeland Semi hermetics usually have the diagram on the inside of the compressor top terminal cover plate
    or ask your Copeland wholesaler for a Copeland electrical handbook - It gives you all the diagrams
    and lists related electrical parts - relays, overloads and capacitors for each model If they still print them in this paperless world
    Or register on Emerson/Copelands site as a contractor and download diagrams from there
    May 2006
    India
    74
    399
    3 phase will be part winding ..just check
