    Feb 2012
    Norway
    3
    Question Stainless steel oil seperator
    Does anybody know of oil seperators with outer housing in stainless steel?
    For offshore use.
    Sep 2003
    ISRAEL
    72
    4,248
    Re: Stainless steel oil seperator
    I will be surprised if you find one, on the other hand, there is a special heat resistance paints, might help you:
    http://www.firesnflames.co.uk/vmchk/...-products.html
    38
    Possibly AlfaLaval, it would a total vessel design costing for a one of, better to use a standard separator and insulate and clad with s/s for a harsh enviroment situation
    Feb 2012
    Norway
    3
    thanks for the answers.
    The idea of making a second layer on the vessel is actully quite smart, and the cost on this one is low. Did not think of that.
    On the other hand, carly said that they might manufacture spesial ones for us.
    Feb 2012
    Norway
    3
    thanks.
    the vessel must be in stanless steel. We cant apply non approved paint ourself. The paint must be fitted and approved in atex on the factory before we can use it.
    Sep 2003
    ISRAEL
    72
    4,248
    If the problem is only the outer housing, it looks to me that it will not cost too much if you ska local shop that manufactures SS fabrication to make it for you, bring the a sample of a steel one, you can buy the internal parts from the manufacturer.
    How many do you need?
    Mar 2005
    638
    Yes you can get a ss oil separator...all it takes is MONEY. I supplied two 600 HP screws to a chemical plan several years ago. It was not cheap.
    May 2006
    India
    399
    Apply weather res coat .......... On its outer
