Results 1 to 12 of 12
    Feb 2012
    United Kingdom
    5
    Choice of Refrigerant
    I'm doing a project and looking for some advice on how to choose which refrigerant to use.
    I'm designing a vapour compression refrigeration cycle which needs to remove 323kW of heat energy in the evaporator. At this stage, the refrigerant will need to be at around -5C as I am cooling to 5C.
    In the condenser I will probably be cooling the refrigerant using air at a maximum temperature of 45C.
    Can anyone give me some advice on what refrigerant to use? I know it depends somewhat on the compressor and pressure used but as these depend on refrigerant it's very hard to choose!
    After reading about it online i've been considering R22 and R134a
    Oct 2008
    newbury
    1,444
    Re: Choice of Refrigerant
    The fact that you are considering R22 means you are either not qualified to design it and will need us to do it all for you or you are a student looking to us to do your home work...
    Fezz up
    Feb 2012
    United Kingdom
    5
    Admitadley I don't have experience in designing refrigerators. I'm a student at university and as part of a group project we have decided that the best option to cool a gas below its dew point is to use the vapour compression cycle. I'm not looking for you to design anything, do homework, or tell me an answer. Mearly offer some advice.
    I have done some research. Mainly through reading a textbook by Chengal and Boles and that is where I had come across R22 and 134a.
    Any advice on how to go about choosing a refrigerant or links to articles which could be of help are still much appreciated
    Apr 2011
    Russia
    140
    Try R12
    Feb 2012
    United Kingdom
    5
    Hmm, you guys clearly dont want to offer any help.
    Apr 2011
    Russia
    140
    You can use R410A, R407C, R404. Any. Check CoolPack software.
    good luck
    Feb 2012
    United Kingdom
    5
    Thank you, i'll have a look at that
    Nov 2006
    708
    You could try R717 as it smells the best
    Feb 2012
    United Kingdom
    5
    I somehow doubt amonia is going to smell very nice!
    3,853
    Have a look at R407F.
    R22 has been banned, it would be like designing a car to run un leaded petrol! Hence the comments above!
    38
    R717 is the most efficient and highly eco freindly.
    The choice is a bit like a menu at cafe, the options are endless.
    Jul 2010
    NTH.QLD Australia
    1,730
    32
    For that amount of cooling, i would probably use R507. 45C ambient would be a little high for R410a.
    BTW, my car runs on unleaded, or E10, premium or 98 octane
    Have to be made of money to use the 98.
Tags for this Thread
