Results 1 to 50 of 69
Thread: thermoking container manuals
18-11-2005, 09:26 PM #1
Re: thermoking container manuals
the BM number is 090171 and the serial number is 0324350730, this is jamcool using ewarts log in
19-11-2005, 12:44 PM #2
OK, no luck with the BM or S/No...
Its a CFII what model should be M something from 4 to 40....can you identify the controller model
19-11-2005, 03:31 PM #3
i see M19.3 as model number the thing is unit still icing back to the suction line,the charge has not changed read the sensors,coil 3670 ohms,return 3290 ohms,and discharge 3310 ohms I think those are ok,it has 9 relays on it K1 to K9 would like to know which control what also any manuals or wiring drawings that can be found.
ANY HELP WOULD BE GOOD
jamcool
24-11-2005, 03:20 PM #4
I have a manual in PDF for you, its 19meg...contactme off list.
John.
01-11-2007, 11:48 PM #5
06-06-2008, 10:43 AM #6
contact Amer Basaeed @Abbar jeddah
06-06-2008, 12:25 PM #7
do you have an email address?
08-06-2008, 03:25 PM #8
I understand you have a PDF Manual for Thermking CFII-M40, is it possible to forward me a copy?
peterkelly@spxservices.co.uk
08-06-2008, 03:53 PM #9
why not make a WIKI somewhere on this forum ,where we can drop all kinds of manuals, or schema's from simple split to highly sofiticated units.
so if someone needs it ,he can simply daownload it.
its only an idea,
Ice
09-06-2008, 02:39 AM #10
18-10-2008, 01:01 AM #11
Hello ,would you please send me somehow that 19MB ThermoKing manuals PDF; have some alarm codes trobleindicator xls for: REEF AL-CODES-list of indicationsalarms and troubleshooting
for:SabroeTNE405D,E ;TNE406 ;tne508/558 ; Carrier 69NT40 521-xx ;69NT40 511-xx ;69NT40 4xx-xx ;Thermo King Controller mP-C ;yP-a ;yP-A+ ;yP-D ;Thermo King CRR-40 ;Seacold Controler CMS 02 ;RMC-Cargo ;DCM9R.....and plenty of other but don't have that Thermo PDF.Thanks
Thermoking
By ddocwra in forum TransportReplies: 10Last Post: 11-09-2010, 11:51 AM -
refrigerated container
By chemi-cool in forum CommercialReplies: 8Last Post: 08-12-2009, 10:15 PM -
Cooling down the water in a 1000 liter container
By Joep Hogenhout in forum Technical DiscussionsReplies: 29Last Post: 21-04-2009, 01:27 AM -
Looking for thermoking genset take outs.
By RaFelix in forum CommercialReplies: 7Last Post: 22-07-2008, 02:04 AM -
Help Deikin MA90AV1 manuals
By JAGw in forum Air ConditioningReplies: 3Last Post: 27-07-2006, 08:23 PM
