    Nov 2010
    Poland
    40
    Bitzer tandem compressors and check valves
    Hello again my dear Friends.
    This time i have a small question about compressor like one in that link: http://pdf.directindustry.com/pdf/bitzer/semi-hermetic-recip-compressors-tandem-kp-110-3/17562-114281.html
    a
    nd check valves... in my opinion it is like two separete compressors connected in parallel so i have to put in check valves on both discharges.
    Am i right?
    Thanks for opinions, Marcin
    Have a nice day!
    Auckland
    74
    3,357
    37
    Re: Bitzer tandem compressors and check valves
    Certainly a good idea to add individual discharge check vavs, plus oil balance line as well.
    May 2006
    India
    74
    399
    Check valve on each compressor , gas balancing line and of course oil balancing line as mentioned in magoo`s post. If low evaporating temp below minus 15 deg c an oil separator would be requd
    Nov 2010
    Poland
    40
    Thanks for replays. That is what i exactly thought .
    Bye!
