    shaahinkh's Avatar
    shaahinkh Guest
    Lightbulb Cooling coil design for ice machines
    Hi guys
    Does anybody know something about the overall heat transfer coefficient of copper tubes with R-22 or a similar gas inside and brine at the outside of the tube? I`m planning to design our cooling coil for ice machines but couldn`t find the heat transfer coefficient since last two months ago.i would appreciate if anyone can help me in this field.
    ps: as you already know, the overall heat transfer coefficient can be calculated by using the conduction heat transfer coefficient of copper tube and the convection heat transfer coefficient of refrigeration gases such as R-22 or etc and finally using the convection heat transfer coefficient of brine. I mean if anybody could give me these parameters i can calculate the overall coefficient by using nuselt or etc.
    thank you in advance and hope to hear from you dears very soon
    shaahinkh's Avatar
    shaahinkh Guest
    Re: Cooling coil design for ice machines
    could you please help as soon as possible?
    3,856
    Haven't a clue sorry! Could measure how much 5/8" pipe is in a 100Kw icebuilder tomorrow if thats any help?
    Why are you using brine if you want to make ice?
    Aug 2009
    New Zealand
    2,554
    26
    Not quite as easy as a simple calc,
    Is it a critical design?
    With or with out ice (how much),
    If with ice base, you calcs upon energy transfer through the ice. this the determining factor not through the copper.
    Aug 2009
    New Zealand
    2,554
    26
    hey Monkey, how many moo moos are you milking for a 100kw ice builder?.
    Auckland
    74
    3,357
    37
    Check the vogt site, will give you some idea on tubes, tube lengths etc., a starting point anyway
