Thread: domestic fridge samsumg
12-02-2012, 08:42 PM #1
samsung mn:RS21FSCV SN:847242BLC00125
Hello guys hope someone can advise me on this domestic fridge freezer.
I found the condenser fan failed. The query is the compressor. The compressor runs for around 30 seconds then cuts off. I suspect this is a safety feature due to the system operating on propane R600. Could anyone confirm this is actually a safety feature and also where can I source Samsung parts.
12-02-2012, 09:37 PM #2
Re: domestic fridge samsumg
pm tonto...
13-02-2012, 10:30 AM #3
check relay on compressor
16-02-2012, 05:27 PM #4
Question.Ask yourself why.Remember we call that a Family fault.A compressor cannot run without the condenser fan.So what happened is your compressor been running without fan for a while until the customer notice that the fridge is out.But it was too late the compressor already internaly damage with high condensing temperature.Red hot.Any fault hapened on a system it cause by a group of component that related together.so replace the comp.good luck
