Thread: Filler help
05-02-2012, 10:15 PM #1
Filler help
Hello
A few years ago I was given a pot of soft filler by an air con fitter, it was a bit like blue-tak or plasticine, maybe a bit thicker.
We used it on a few jobs to seal up ways through walls, portakabins, cold rooms etc...
It is made for this purpose as a quick, weatherproof alternative to sand & cement or foam etc... the stuff we had was dark green but I think it comes in other colours.
Does anyone out there know what this stuff was called and where I can get it, I've done a few searches on line and asked at a few trade counters but nobody knows what it is.
It's very handy for weathering cable ways through masonry etc...
05-02-2012, 10:22 PM #2
Re: Filler help
05-02-2012, 10:36 PM #3
Re: Filler help
permagum !! not sure which suppliers do it but you can use it for resealing pipe entries in refrigeration cases.
This may be the stuff !!!!your only as good as your last job
05-02-2012, 10:37 PM #4
Re: Filler help
05-02-2012, 10:46 PM #5
Re: Filler help
Duct Seal Putty
http://www.rainbowtech.net/products/docs/d3d94468649ad98a923/Literature.pdf.pdf
09-02-2012, 11:35 PM #6
Re: Filler help
Thanks, I will have a look.
Actually install monkey, it is like play-doh only more durable and contains oil I think.!!!!!!!
10-02-2012, 12:18 AM #7
Re: Filler help
never used it-seen it on the shelves years ago-last resort roof and gutter sealant-from travis perkins - black non setting mastic can be applied wet
10-02-2012, 12:40 AM #8
Re: Filler help
