06-02-2012, 11:50 AM #1
Foster cold room door fittings spares enquiry
Hi all ..... wonder does anybody know of a supplier of the fittings for the foster type cold room door ....... am espescialy after the grey blocks with the white nylon roller and the oppossing barbed plate that locates under the roller on the actuall door ........
Have had a go round the net but can only find fermod stuff and that looks way different ...
Brian
06-02-2012, 12:45 PM #2
Re: Foster cold room door fittings spares enquiry
Like this?
http://www.coldroomparts.co.uk/epage...Products/F0005
Got one recently, not sure if it was from these peeps, was made of plastic instead of ali but worked ok.Mostly found in Oxfordshire, UK :)
14-02-2012, 06:34 PM #3
try a compony called caital calling they should be able to help you
14-02-2012, 07:55 PM #4
This is one of my favored manufacturers
http://www.fermod.com/products-list....oor&zcat_id=12
