    Somerset
    70
    4,700
    47
    Ermeto Hydraulic fittings (6,8,10 + 12L)
    I have had several 12mm (12L) fittings fail recently.
    IE, An Oil leak develops releasing refrigerant with it.
    I always change the fitting for new.
    Has anyone had any success just re-tightening these up?
    11,024
    Re: Ermeto Hydraulic fittings (6,8,10 + 12L)
    Looking at the data sheet it seems that they can be undone and then remade but looking at the sectional detail I suppose a retighten might work.
    They state however that once done-up tight that it is a perfect leak free joint (yeah, right).
    http://www.lister.co.uk/Hydraulics/higheoeo2.pdf
    page 1
    Auckland
    74
    3,357
    38
    Hi Grizzly.
    I use alot of swageloc fitting etc., they stipulate that they be torqued up and backed off 1/4 of a turn. So me being me tighten till elbow clicks and back them off. Resealable disconnects the same process. Never had a problem. Don't know what the back off effect is but seems to work.
    Somerset
    70
    4,700
    47
    Thanks guys.
    The one I checked yesterday (Had sprung a leak!) had an internal hairline fracture.
    So it was replaced.
    3,362
    Grizzly,
    VSD on screw compressor can cause fractures of tube, maybe thats what you have?
    Certain frequencies cause vibration & tube gets metal fatigue.
    Somerset
    70
    4,700
    47
    Grizzly,
    Your getting scary Sherlock!
    A SAB 163HR Rotatune with vibration resonance at 2 points, all sorted now.
    But thanks for the input.
