Results 1 to 19 of 19
Thread: Blast Freezer
    Feb 2003
    United Kingdom
    66
    8
    Cool Blast Freezer
    Hello to all,
    My request is a simple one,
    I may be asked to explain why it is preferable to blast freeze (-25c) freshly butchered meat as opposed to the tradition method of -20C.
    What effect does either have on the meat?
    What are the advantages/disadvantages of either method?
    Look forward to your replies guys,
    Regards,
    Kev
    Oct 2004
    Scotland
    1,454
    21
    Re: Blast Freezer
    Hi Kev,
    The bigger the temp diff - the quicker it will get the meat cold.
    Which will help stop bacteria forming/growing.
    Chillin
    and go get a cuppa
    Jan 2003
    Venezuela
    58
    22
    Re: Blast Freezer
    Kev,
    There are many things to consider when freezing food. I have attached a few pages from a food science book.
    Regards,
    Jan
    Attached Files Attached Files
    Oct 2005
    IRAN
    878
    Thumbs up Re: Blast Freezer
    Quote Originally Posted by kev
    Hello to all,
    Hi there,
    In the blast freezer the temperature is normally -35° or -40°C. If the room temperature is -25°C then it is a normal cold room.
    In order to preserve the quality of the food and also reduce the core temperature to the required value then the food must be cooled very quickly with low temperature.
    If not then the ice build up on the surface of the food will act as an insulation therefore, the core temperature will not reach to the required temperature.
    Even Einstein Asked Questions
    Aug 2005
    5,302
    Re: Blast Freezer
    Quote Originally Posted by PobodysNerfect
    The pages you provided look very interesting. Can you provide the book information please?
    Title, Author, ISBN, etc.
    Thank you in advance.
    Regards,
    US Iceman
    Mar 2004
    Denmark
    65
    21
    Re: Blast Freezer
    This tread is very interesting, because I am going to make some test regarding this problem in the next 2 months.
    Here in denmark many butchers let the beef cattle hang
    about 2 - 3 weks before the cutting out and this means that the meat will lose about 8-10 % of the weight in this period with a traditionel cooling room.
    Concerning pig meat, they blast freeze them shortly before they are going to the cooling room, if they not do the cut out the next day, but let them hang 3-4 days they will have to pay more for the cut out.
    I have build a new cooling trailer, witch allov a cooling temperature at 1,5° C and with a RH about 95-96%.
    I think this can reduce the drying up of the meat.
    I will bring the test in this forum.
    Best regards
    Carlo Hansen
    Nov 2004
    Sri Lanka
    77
    Re: Blast Freezer
    Kev,
    Regards,
    Jan
    Dear jan,
    I was trying to see what is in the attachments but failed due to a reading error of the Acrobat Reader.Would you please check on this and advice me.
    Thanks,
    Patrickj
    Oct 2003
    5,630
    34
    Re: Blast Freezer
    What do you mean with the traditional method? Hanging the meat in an ordinary freezer at -20°C?
    Blast freeze fastens the freezing process and prevents that the water molecules inside the meat can stick together to bigger water droplets which can form meat deforming cristals. (the freezing water molecules tears the meat inside)
    Jan 2003
    Venezuela
    58
    22
    Re: Blast Freezer
    Quote Originally Posted by patrickj
    Maybe you need a new Acrobat Reader.
    Quote Originally Posted by Hansen
    Carlo,
    What are you going to transport in that trailer? Pig carcasses coming from the blast freezer, completely chilled pigs or something else?
    Regards,
    Jan
    Mar 2004
    Denmark
    65
    21
    Re: Blast Freezer
    Hi Jan
    The trailer is not for transport. It is made for test with a
    new cooling system.
    It is easy to place the trailer on diff. places.
    I am going to make some test by a couple of butcher`s, they have shown interest for this new system.
    Cooling system:
    http://www.wulffdata.dk/
    Best regards
    Carlo Hansen
    Oct 2003
    5,630
    34
    Re: Blast Freezer
    Quote Originally Posted by Carlo Hansen
    2 to 3 weeks hanging there
    Here, it must hang legally due to the BSE crisis 2 days so that all the tests can be done, but then it's cut immediately and the parts that are not direct sold are vacuum packed or packed in an inert atmosphere
    Oct 2005
    In a 2 bedroom unit. Why's That? :)
    314
    Re: Blast Freezer
    Is meat hung for up to 15hrs after slaughter and before freezing still?
    Or do most abattoirs send the carcass straight through the washer and into the blast freezer?
    15hrs was an old guideline for enzymatic tenderisation.
    Apr 2006
    41
    1,620
    Re: Blast Freezer
    Same here traditionaly it is hung for 3 weeks or so by all local farmers.
    eserunlu's Avatar
    eserunlu Guest
    Re: Blast Freezer
    Hi to all.
    someone can help me?? how can i calculate blast freezing capacity? and someone can give me the data tables including blast freezing temperatures, blast freezings times of all foods, vegetables etc.
    u can e-mail me also
    eser_unlu@hotmail.com
    Oct 2003
    5,630
    34
    Re: Blast Freezer
    Location 'jhgj', where's that somewhere on earth?
    How you can calculate the freezing time? With Planck constants/numbers, Biot number, ....
    I think you're not aware that a blast freezer is one of the most difficult jobs to do it right. A lot of experience is involved which can't be given just in some basic information.
    Freezing time is based on so many variables that numbers can be given from 10 minutes freezing time till 2 days.
    Ohhh, BTW Welcome.
    nevgee's Avatar
    nevgee is offline Veteran Poster I am starting to push the Mods: of RE
    May 2006
    Yorkshire
    72
    417
    Re: Blast Freezer
    As an off shoot, to slice bacon it was necesary to stiffen it by freezing down to say -4 C this took time and caused a loss of moisture during the proccess. This loss in moisture equated to loss of profit ..so we built blast freezers to quickly freeze the exterior surface of the bacon sides say 5-6mm then the sides were put into a tempering chill room to stiffen up. The quick freeze of the surface then prevented moisture loss from the bacon sides thus keeping weight thus saving profits for ASDA and Danish Bacon ...
    Blast freezing would normally have been done at -35/-40C but freezing meat too quickly can cause cold shortening or toughening the meat especially if done straight from slaughter. I thought there was still a need to let the meat hang before being frozen.
    Reality is an elusion created by alcohol deficiency. Quaff and enjoy. [Yorkshire, UK]
    Aug 2005
    5,302
    Re: Blast Freezer
    Blast freezers and coolers are almost a complete science to themselves. Some lunch meats are also cooled for slicing to keep the fat from smearing.
    Each product is different and each process required or used can be different.
    And...freezing times are always a fun discussion which I think is what Peter was pointing out.
    sudarshan's Avatar
    sudarshan Guest
    Re: Blast Freezer
    What Is The Freeezing Time Required For Meat And Vegetables Above & Below Freezing Point And At The Time Of Latent Heat Of Fusion For Calculating Tr
  19. #19
    eserunlu's Avatar
    eserunlu Guest
    Re: Blast Freezer
    'jhgj' means i have no time to write place im from turkey. i need blast freezing times data sheets for all foods. is there any table for this? sometimes i need for vegetable, meat, chicken etc.
  1. Blast freezer temperature problem. Please help!!!
    By volta in forum Technical Discussions
    Last Post: 10-05-2010, 04:54 AM
  2. Blast Freezer Questions
    By rickmor in forum Industrial
    Last Post: 11-04-2006, 08:15 PM
  3. Blast Freezer Evaporators Selection
    By Mahmoud in forum Fundamentals
    Last Post: 21-09-2005, 04:31 PM
  4. Blast freezer
    By chemi-cool in forum Commercial
    Last Post: 09-03-2005, 09:58 PM
  5. Blast Freezer Frosting
    By stcornish in forum Industrial
    Last Post: 15-03-2002, 03:57 PM
