    Jun 2009
    saudia arabian
    21
    leak in ammonia plant
    HI EVERY BODY,One day my ammonia plant running smoothly with good temperture then suddenly their is leak in heatexchanger ammonia start to come out to atmospere then i check but i cannot find why this happen can any help me to know how this one happen . thank you all
    Sep 2009
    Iran
    462
    12
    Re: leak in ammonia plant
    could you give us more information about you system and your heat exchanger. to find leaks in NH3 is very easy ((smelling )) is a best way .,
    Pennsylvania
    45
    113
    11
    Sulphur sticks are handy to catch very small pinhole leaks but it's very rare to get a leak on an ammonia system without corrosion unless you are leaking at a flanged joint of some type.
    Aug 2009
    New Zealand
    2,556
    Could it be that you had a pressure relief valve, opened releasing NH3, then resetting.
    Jul 2008
    Singapore & Malaysia
    71
    30
    Best method to check tube leakage, if nonferrous material use Eddy Current Tubing Examination and if ferrous material use Remote Field Eddy Current (RFT)/Internal Rotary Inspection System (IRIS) as such NDT methods could solve your problem.
    If you test 100% of the tubes than you will know which tube having wall thickness loss and the percent of wall loss and take quick action to plug off the defect tubes, in anticipation of tube failure.
    Mar 2012
    United Kingdom
    Could you give better information surrounding your refrigeration plant?
    I.e. Make of unit, type of heat exhanger (PHE/Shell and tube)
