Results 1 to 10 of 10
    Somerset
    69
    4,713
    Now that's what I call in need of a clean!
    Yep, pulled this one out of a comp sump today.
    There are 2 gauze strainers (1 fine, 1 course.) then a paper element filter in the middle.
    It had run for 2 yrs since the last service. I showed it to the Engineering manager prior to using their parts cleaner bath.
    He took some photo's of it as well!
    I think it may form the basis of his argument to his senior management. For more frequent servicing?
    Jun 2009
    Lusk , Dublin
    1,115
    Re: Now that's what I call in need of a clean!
    That needs a good scrubbing ,a bit like me
    Or you could always just replace the elements (Like I'm sure you did)
    Stu
    Tool's ? check ! Condom's ? check !
    3,362
    Grizzly, how did it ever get enough oil pressure to run?
    Its amazing how some things keep going after you pull them apart.
    3,853
    Hi Grizzly!
    Is that scale from steel pipework on the filter? I'm guessing its from an ammonia system.
    Can't have been doing the compressor much good!
    Jon
    3,362
    I'm guessing its out of that Sabroe 8-180 you were having a fight with the new type valve springs.
    Sabroe kept changing oil pump filter design, but this one still works well after, what 45 years!
    Two man job to put in cylider liner with all that double valve gear on top of liner.
    I've rebuilt one, thats enough.
    They last forever running direct drive 750rpm, even with dirty filter.
    Somerset
    69
    4,713
    Two man job to put in cylinder liner with all that double valve gear on top of liner.
    I think I will start calling you Sherlock my friend.
    Yes and It was still running!
    88kg per cylinder head absolute killer.
    Thankfully the pain killers are working.
    MS. Yes its ammonia,
    Scale from their treated water is a definite issue, but Hey last time I rebuilt said machine was 2 years ago.
    Which we would only warranty for 6 months, now they are saying they want to flog it! Sorry run it,
    for 2 more years.
    Until the new Mycom plant is finished...
    Watch this space!
    Stufus.
    Believe it or not! The strainers actually cleaned up a treat. Obviously the filter cartridge was new.
    Prior to stripping oil pressure was not an issue. The comp was running hot with 2 heads having head cooling issues.
    Cheers guys.
    May 2009
    New Zealand
    141
    15
    I bet the new style of oil filter they have for the 100 series would have blocked long ago in those conditions. Do they have an upgrade for the 180 series?
    Somerset
    69
    4,713
    Quote Originally Posted by Superfridge View Post
    I am not sure on that one?
    All I know is that the filter cartridge that was ordered was the correct one.
    If I get chance I will check against the part numbers.
    Apr 2009
    home
    32
    Did that oil filter have a spring loaded bypass?? Those filters are terrible!z
    3,362
    Quote Originally Posted by weagle View Post
    The replacable filter is a bypass filter that cleans a small amount of oil off dischage of pump.
    It has a tiny orifice off main oil line feeding this filter & is continually conditioning oil at "X" micron, finer than cleanable filters on suction of oil pump.
    There are no spring loaded bypass or anything, like on some hydraulic oil filter housings in case filter is blocked
