    Jan 2012
    Ireland
    "Ammonia as a refrigerant"
    Im doing a project as part of my final block of training as a refrigeration technician.
    I have chosen to research Ammonia as i have no experience in the workplace with it and would like to learn more about it.
    I would appreciate any info at all, especially from experienced technicians with experience of Ammonia on a daily basis.
    Oct 2006
    1,843
    21
    Re: "Ammonia as a refrigerant"
    Quote Originally Posted by PaulYeates View Post
    Hello Paul.
    Ammonia is one of the best refrigerants you could ever hope to work with.
    One thing about Ammonia is it will always and I repeat always let you know it is out of its box.....
    Ammonia as far as efficiency goes is the next best thing compared to water for transfering heat energy.
    Water will also absorbe NH3 so it can be safely vented through water to attmosphere making it
    environmentaly good. It has no potential to damage both the Ozone layer or cause climate change.
    It is easy to work with if you respect it and if you don't respect it, it gives you a slap to get your attention.
    I can't think of anything more but others will.
    taz
    Oct 2006
    CORDOBA -ARGENTINA
    75
    69
    ammonia venting
    Taz 24 , I´m sure about it, and I knew it for years.
    Code:
    Water will also absorbe NH3 so it can be safely vented through water to attmosphere making it environmentaly good. It has no potential to damage both the Ozone layer or cause climate change.
    But I need some "oficial" place or safety standard where I can step on it , to show it to my customer.
    Did you know where I can find such rule??
    Jan 2006
    Croatia
    68
    2,261
    31
    Hi, PaulYeates
    Welcome to RE forums...
    I'm ammonia guy for 30+ years .... don't know what you need, but you can take a look here... all about natural refrigerants ....
    http://www.eurammon.com/englisch/html/index.html
    something about ammonia properties...
    http://www.osha.gov/SLTC/etools/ammo...ndex.html#pure
    something about ammonia manufacturing.....
    http://www.cheresources.com/ammonia.shtml
    something very important to learn ....
    http://www.nh3gccc.com/ammonia-refri...nformation.htm
    hope you'll find something of help...
    Some will not agree with me, please, do not forget, ever: ammonia is a deadly dangerous substance, but with its smell always warning us as a friend ... my friend I'm here, be careful .... other, not bad smelling and according to general assumption "good" and "green" gases - without bad smell - just give a deadly hug and kill us in silence by suffocation.
    Best regards, Josip
    Jan 2012
    Ireland
    Thank You Taz....much appreciated!!
    Jan 2012
    Ireland
    Thank You Josip, appreciate your help!!
    Somerset
    69
    4,698
    Paul.
    We all mention the potential negatives of Ammonia.
    But they are no more than any other toxic or harmful substance.
    Some simple positives are....
    Ammonia is a natural substance which does no harm to the environment or ozone layer.
    Because it's a natural substance it's very cheap to produce and therefore cheap to purchase.
    An ammonia plant generally uses a third less energy for the same duty when compared other refrigerants.
    Historically their use has been restricted to larger systems, where the initial install costs were absorbed due to their longevity and cheaper operational costs.
    Now with copper and refrigerant prices so high.
    Using ammonia has never been such a good option.
    Sadly there are still to many short sited Accountants controlling engineering budgets.
    From an Engineers view Ammonia makes a lot of sense but not for all applications obviously.
