    Dec 2006
    Indonesia
    68
    37
    How to calculate condensing unit and cooling coil?
    Hi all,
    I am looking for the formula to calculate the proper condensing unit for 75,000 BTU and the cooling coil for 65,000 BTU? Is there a simple way for it?
    Thank you.
    Dec 2006
    Indonesia
    68
    37
    Re: How to calculate condensing unit and cooling coil?
    Anyone?
    Auckland
    67
    3,362
    31
    What is the application temps, and ambient temps, single compressors or multi compressors. More information would get a few responses.
    Aug 2009
    New Zealand
    2,556
    I would use this formula
    a = duty
    b = size of condensing unit at working conditions
    a=b
    normally works for me.
    Damn that is the metric version
    Try this for imperial
    b=a
    May 2006
    India
    68
    400
    12
    INFO REQUD :
    SST :
    DST :
    REFRIGERANT TO BE USED:
    REFRIGERATION LOAD :
    FIRST SELECT A COMPRESSOR .........
    THEN RAISE THE SUCTION SAT TEMP BY ABOUT 7 TO 10 DEG C .....
    FIND OUT THE HEAT REJECTED AT THE CONDITION & THAT WILL BE THE CONDENSER HEAT REJECTION
    GIVE THE CONDITIONS & WILL WORK OUT A COD UNIT FOR YOU
    FOR ANY HELP FURTHER SEND ME A PM : ddk0123@gmail.com
    Oct 2003
    56
    5,519
    28
    MF, I think you made a fault. It's not b=a for metric but b= c...or was it c=b...mmm...too long i used this formula
    Aug 2009
    New Zealand
    2,556
    Peter
    Always will to accept alternative theories, especially when I am wrong!, so I will have to spend weeks re-writing all my software programs, to ensure that these complex calculations are correct and up to date.
    Thank you "O Masterful One"
    PS; Happy New Year
