Thread: Hello.
    Jan 2012
    pk
    35
    1
    Hello.
    Hello.
    I was wondering how many of you have considered stainless steel tubing as an alternative to copper? It is not that I am trying to use it, because I probably don't have the tools for it,
    Sep 2003
    ISRAEL
    72
    4,248
    Re: Hello.
    Its cheaper but you need a Tig welder, a bottle of Argon and it can not absorb vibrations as copper.
    3,355
    Re: Hello.
    sweetmango,
    We are using it in industrial already for some time.
    Also on a large R22 plant several years ago, its cheaper than it used to be & easy to handle & no painting.
    For smaller lines annealed copper can be used same as copper.
    Somerset
    69
    4,698
    Re: Hello.
    Slightly confused there my friend!
    Annealed copper is still copper, only it's been heated to make it malleable (Soft and pliable).
    As copper age hardens.
    Apr 2006
    55
    1,908
    30
    Re: Hello.
    Hi sweetmango
    no relation to the boys favourite 'sweetmeg' are you ?
    If the World did not Suck, We would all fall off !
    Dec 2010
    Toronto, Canada
    1,454
    Re: Hello.
    I've been looking ito it and there are high silver content brazes for use on 300 series SS. Handy Harmon 380 to 505 series flux core sticks. It works really well and we are trying it for shock at the moment and so far it is really strong. We are drilling a 3/8" test hole in 1-3/8" thin wall pipe for the tests. HH brazes are a bit pricey but it doesn't take much.
    CM, that is one weird avatar.......
    3,355
    Re: Hello.
    Quote Originally Posted by grizzly View Post
    slightly confused there my friend!
    Annealed copper is still copper, only it's been heated to make it malleable (soft and pliable).
    sorry, correction, its meant to say annealed stainless steel for smaller lines is like annealed copper to work with.
