Results 1 to 12 of 12
14-01-2012, 09:52 AM #1
Daikin RXD80CV4 / FTXD80CV48 Service manual
Hi guys does anyone know when i can download a service manual for this unit or if someone could possibly email me one?
I have checked the daikin extranet but can't find anything on that model, probably because im in Australia?
15-01-2012, 05:50 PM #2
Re: Daikin RXD80CV4 / FTXD80CV48 Service manual
16-01-2012, 12:46 AM #3
Hello my friends!I am excited with the amount of information can be found here. I would be pleasant if someone had the service manual of the Daikin FTXN 35K(indoor)-RXN 35K(outdoor). Thanks a lot!
16-01-2012, 08:47 AM #4
Thanks for that link but has anyone got anything more specific regarding my particular model number?
Reason i ask is the unit im working on had a power spike go through it. I checked the indoor PC board and the fuse was blown but i was unable to remove it and change it as it was soldered onto the board. I had a look at the outdoor unit and couldnt see any fuses blown or PC board damage but im unsure if i should actually quote to replace those outdoor boards to cover myself. I noticed that little pcboard when you take off the piping cover with the service checker port and LED light wasn't blinking or anything.
16-01-2012, 09:43 PM #5
Solder on a new fuse and check it.
The fuse is there for protection.
16-01-2012, 09:57 PM #6
Last edited by install monkey; 16-01-2012 at 10:05 PM. Reason: thought it was lightning that damaged pcb
16-01-2012, 09:59 PM #7
16-01-2012, 09:59 PM #8
Who mentioned lightning ???
16-01-2012, 10:12 PM #9
as its power to outdoor first,change all pcb,s transformers and test every component as you cannot ensure its gonna work
18-01-2012, 07:28 AM #10
Thanks guys but after speaking to tech support and getting prices on all the pcboards im just goign to quote on a new unit. All parts came to around $1400!!!!!!
15-02-2012, 12:29 PM #11
Hello kind people can anyone tell me what pipe size this unit has? Ive got the approval to replace the unit i just want to know what exsisting pipe is there.
15-02-2012, 12:47 PM #12
ignore i found it
Liquid (mm) Ш9.5 Gas (mm) Ш15.9
