Results 1 to 9 of 9
    Jan 2012
    mauritius
    1
    what determines the pressure in the evaporator
    Hi all,
    I am new to the refrigeration industry.
    Can someone tell me what determines the pressure inside the evaporator ? They always say that the expansion valve has an orifice which causes a drop in pressure. Would that mean that depending on the size of the orifice, i would get a certain pressure in the evaporator ?
    Apr 2006
    49
    1,920
    23
    Re: what determines the pressure in the evaporator
    Quote Originally Posted by seadive View Post
    Basic refrigeration principles
    If the World did not Suck, We would all fall off !
    Feb 2007
    2,477
    Welcome to the forum Seadive.
    Look at the expansion device as the tap above your sink, both will regulate flow.
    Just like the opening in the tap doesn't (on it's own) regulate the water level in your sink, the expansion valve (or it's orifice) will not regulate the evaporator's pressure.
    Apr 2001
    72
    5,069
    28
    Apr 2006
    49
    1,920
    23
    Wow do I need glasses or has Gary returned to grace us with his presence
    Happy new year Gary
    Apr 2001
    72
    5,069
    28
    Happy New Year, everyone.
    Every once in awhile, I wander off and get caught up on other things. In Australia, I think they call it going walkabout.
    Jul 2010
    manchester
    212
    9
    going wup wup !!!!!!!
    your only as good as your last job
    Mar 2002
    Tehran
    48
    38
    some other factors like ;expansion upstream pressure (condensing pressure),evaporating temp depending on load,compressor capacity relative to evaporator,right situation of equalizer and thermobulb,adjustment regulation of orifice.
    S.P
    Apr 2006
    49
    1,920
    23
    I'm confused, as I always thought it was down to the amount of energy in the refrigerant
