Results 1 to 9 of 9
Thread: reclaiming concerns!!!
09-01-2012, 07:12 AM #1
hi there just seeing if it was possible to reclaim refrigerant from a condenser while its not working at all with out a reclaim unit or recovery bottle????
the reclaim unit we use is currently getting serviced (stuffed)
is there any way of pumping it down???? vac pump???
cheers
09-01-2012, 09:24 AM #2
Re: reclaiming concerns!!!
....... No.
...and she said "give it to me you big fridgie"
09-01-2012, 10:18 AM #3
Many wholesalers have reco units for hire, or failing that subcontract the job to someone with more experience.
11-01-2012, 09:22 PM #4
I think the 'eson' was missing JOKesonU
If the World did not Suck, We would all fall off !
11-01-2012, 10:54 PM #5
i use an aspen perisaltic,as it will syphon up 1 mtr,self priming,and has an overrun facility to ensure all gas is reclaimed,small,easy to carry on rooftops,and the 1/4 connectors are ideal,also it is ip55 rated-pulls about 12kg/hour
11-01-2012, 11:02 PM #6
IM, I never thought of that...
But only 12 kg/h.
Hmm, what do you think it will do in push/pull mode?
Would save my back
11-01-2012, 11:19 PM #7
Wet and dry Henry, bags the gas up nicely
12-01-2012, 12:19 AM #8
16-01-2012, 04:06 PM #9
Before I bought a reclaim unit, I used a freshly vacced cylinder in an esky (cooler, chilly-bin..) surrounded by dry ice and bathed in methylated spirits. ~-70C will pull most stuff out slowly.
