Results 1 to 12 of 12
    Jan 2012
    Chile
    11
    is there a better antifreeze than ethylene glycol?
    Hello everyone
    I'm currently working with a cooling system that operates with a 40% volume aqueous glycol solution, i'm trying to find if theres a similar antifreeze that will provide better heat transfer while maintaining (or idealy improving) other properties (such as viscosity, fouling factor, etc)
    thanks!
    11,025
    Re: is there a better antifreeze than ethylene glycol?
    What temperature are you operating this solution at as the data changes with temperature?
    Apr 2011
    Russia
    140
    Check NaCl, CaCl2
    Sep 2003
    ISRAEL
    72
    4,248
    Propilane Glycol is what we use.
    Mono-Propylene is the food grade glycol if any possiblity of food contact
    Dec 2010
    Toronto, Canada
    1,454
    Propylene glycol is the best and it can be supplied natural or with different types of inhibitors depending on temp range. Google "Tyfocor glycols" We must have non toxic glycols in our systems.
    manchester
    5,639
    ive heard unclefrost is better than aunty freeze!
    Dec 2010
    Toronto, Canada
    1,454
    depends if he supplies alcohol
    Hi Mike Holm.
    what anti freeze do you use in your vehicles, all eco freindly stuff I hope. Toronto gets nut cracking cold I beleive in winter.
    Dec 2010
    Toronto, Canada
    1,454
    we still use highly toxic ethylene glycol except me as i buy the proplyene by the IBC (1000L). I think some stores sell non toxic stuff but it is not seen much.
    9C here today and yesterday. don't know if it broke a record but it won't be taxing the antifreeze.
    What do you use?
    Apr 2011
    Russia
    140
    We use both ethylene and propinene.Propylene is more expensive, non-toxic and has WORSE heat transfer. That is Juicetavo asked.
    Many years ago we used NaCl and CaCl2.Cheap, non-toxic but aggressive.
    Dec 2010
    Toronto, Canada
    1,454
    Propylene is not that much less in heat transfer and only a bit more money. The negative points don't outweigh the positive points. Number 1 is that if I was in Austria, I could put it in wine after I used it in the system
