    3,856
    Reciever PRV vent pipe???
    Whats the propper practice with these things, i assume they need piping outside of the plant room but is there any guidlines on where to and to what height and does it need a thingy on the end to stop it getting bugs water or stuff in it and blocking it up?
    Did see a mushroom shaped brass thing for boiler vent pipes and wonder if something like this would be an idea...
    or a whistle off a steam engine
    Jon
    manchester
    5,639
    Re: Reciever PRV vent pipe???
    boiler vent pipes are supposed to vent to a visible area,safely and discharge either against the wall or at low level as you have think if a relief valve discharges hot water at 3.5bar or gas at 28 bar then if you harm anyone then your up in court,do not pass go,or collect £200!!
    Jun 2009
    Lusk , Dublin
    1,115
    Discharge is required to be at least 4.5mtrs above ground level and 6mtr from windows,doors or vents.The discharge should be terminated in a manner which prevents discharged refrigerant being sprayed directly at individuals nearby and prevents debris from entering and clogging the discharge port . A specially designed diffuser is recommended,such as a whisper-flow vent diffuser.
    http://www.documentation.emersonproc...102747x012.pdf
    SOURCE=unknown APC maybe.
    Stu
    Jun 2009
    North East England
    712
    Pretty sure it has to be in steel pipe work too
    3,856
    Just to be clear, this is a relief valve on a liquid reciever and not a boiler as i may have given the impression it was
