Results 1 to 10 of 10
Threaded View
09-01-2012, 01:52 PM #10
Re: Help !! NRV requirement in a KTK chiller.
Refrigerant will always move (migrate) to the coldest part of the system ,it eliminates the need for compressor operation as the fans and heat diff with the water in the hydraulic circuit and cooling tower provide the heat gain and rejection the maintain changes in state(vapour to liquid and liquid to vapour) effectively providing free cooling.
