Results 1 to 11 of 11
Thread: Entropy
    Oct 2005
    IRAN
    878
    Thumbs up Entropy
    Can enyone explain in a very simple manner what is the Entropy? I know the thermodynamic definition of it.
    Cheers.
    Even Einstein Asked Questions
    Aug 2005
    5,302
    Re: Entropy
    This is a question that always generates more questions.
    Try these websites:
    http://www.2ndlaw.com/
    or,
    http://www.entropylaw.com/
    These links have a lot of information and explanations that can hopefully explain this for you.
    Regards,
    Oct 2005
    In a 2 bedroom unit. Why's That? :)
    314
    Re: Entropy
    Quick question...R U in the trade?
    Entropy is found on the Enthalpy chart which is the fundamental of design and fault finding in the refig industry.
    Unfortunately I don't fully understand entropy myself only that it is a measure of energy and work done in the commpressor.
    Don't quote me though. Google PH charts or pressure enthalpy charts.
    Some one tell me if I'm wrong I'm only a 1st yr apprentice.
    rbartlett's Avatar
    rbartlett Guest
    Re: Entropy
    Entropy entropy -they've all got it entropy !! ;-))
    cheers
    richard
    Dec 2004
    LEBANON
    44
    854
    21
    Re: Entropy
    Hi Richard , seems that you are very familial with the entropy concept , can you define it for us ?
    Dec 2004
    LEBANON
    44
    854
    21
    Re: Entropy
    Oct 2005
    314
    Re: Entropy
    Entropy. 'measure of the "unavailability" of a systems thermal energy for conversion into mechanical work.'
    Adiabatic Process.
    Compression is adiabatic when there is no heat transfer to the cylinder wall, or from the cylinder walls during compression, so that an amount of energy equal to the work done on the vapour is set up in the vapour as internal energy, and vapour temp increases accordingly.
    Australian refrigeration and air conditioning '4th ed'
    West 1 services."graham boyle" 2004
    This is assumed for plotting Ph charts.
    Jul 2005
    Detroit,USA
    52
    31
    Re: Entropy
    My quick definition of entropy is that it is a measure of the "disorder". The concept of entropy can be applied to anything, a clean and orderly house has less entropy than a messy and disorderly house.
    The application to thermodynamic systems is very important, as the 2nd law of thermodynamics tells us that for any real process the entropy of everything involved (sometimes just referred to as the universe) in the process must increase. In other words, there will always be inefficiencies and perpetual motion machines are not possible.
    It is possible to straighten up a house and decrease it's entropy, but the entropy that you generate in the process will be greater (you will burn energy doing the work).
    For thermodynamics, the concept of entropy lets you determine the actual path that a process will take. The 1st law of thermodynamics will tell you how energy can change forms (like from kinetic energy of motion into thermal energy). The 2nd law will tell you which energy change will actually occur.
    For refrigeration, entropy is very important for determining how a compressor will operate with a given refrigerant and conditions.
    As you know the compression process generates both higher pressures and higher temperatures, both are forms of increased energy (or enthalpy) of the refrigerant, but how much temperature rise will accompany a given pressure rise?
    Entropy lets you determine how much pressure rise will accompany the temperature rise, and vice-versa. The entropy of the compression process must increase, and since a compressor is a real device, it must have an isentropic efficiency less than 100%.
    The old joke about entropy, mostly on bumper stickers of physics professor's cars is:
    Entropy just aint what it used to be.
    (The entropy of the universe must be increasing, since it is not possible for it to ever decrease)
    I hope this point of view helps,
    -Erik
    Jun 2005
    California
    394
    Re: Entropy
    Quote Originally Posted by lana
    Cheers.
    A simple explanation: Energy spontaneously disperses from being localized to becoming spread out if it is not hindered from doing so.
    Oct 2005
    IRAN
    878
    Thumbs up Re: Entropy
    [QUOTE=Erik Detroit]My quick definition of entropy is that it is a measure of the "disorder". The concept of entropy can be applied to anything, a clean and orderly house has less entropy than a messy and disorderly house.
    Thanks Erik, it was a real simple explanation.
    Dec 2004
    Weihai,China
    800
    Re: Entropy
    Entropy is more philosophy meaning than enthalpy. In practical work ,enthalpy is widely used. I think Entropy is the increasing function of the time. Minus entropy is needed to control the system in order and energy input needed at the same time.
  1. Q=? h1=? mechanical schematics
    By fridg in forum Technical Speculations
    Last Post: 19-03-2006, 01:43 PM
  2. PH diagram theoretical cycle
    By REL in forum Training
    Last Post: 11-12-2003, 03:41 AM
  3. Entropy
    By Prof Sporlan in forum Fundamentals
    Last Post: 08-12-2003, 11:43 PM
  4. Thermodynamic Laws
    Last Post: 08-10-2002, 12:37 AM
  5. Psychrometrics
    Last Post: 01-12-2001, 06:48 PM
