    Scotland
    312
    11
    Cool Burn out dryer on small freezer cabinet
    Hello Everybody
    I am changing an R134a compressor Unidad Hermetica GL99AA, it's on a small freezer cabinet.
    I presume this will need a burn out drier, I normally work on bigger stuff so any advice would be appreciated. Thanks
    43
    3,794
    38
    Re: Burn out dryer on small freezer cabinet
    I'd probably just fit a 032 sporlan if its a small cap tube system, not sure how the extra volume of a suction drier would affect the system. But if its really burnt then i suppose it would need one to get the acid out and then remove it.
    I think a factor is with small systems that they are often cheaper to replace than fix propperly.
    Jan 2009
    bristol
    11
    I'd fit burn out drier add some acid away then remove b/o drier after week or so and fit another 032 liquid line drier.
    43
    3,794
    38
    Quote Originally Posted by aliman View Post
    Does the acid away work ok with poe oil?
    Jun 2009
    Lusk , Dublin
    1,120
    It does if you use the one for POE oil.
    http://rectorseal.com/index.php?site_id=1&product_id=21
    Stu
    Tool's ? check ! Condom's ? check !
